Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
KSRS22FGWHO4 INTERIOR LIGHT LOCATION
When I opened the side by side frig door, there was a bright flash of light. It appears that a light blew. I couldn't find bulb. I found socket (control panel) with no bulb. So I put in lightbulb but there was no light. There used to be a working light in the frig. I just can't find where to install new 40watt appliance bulb. Any suggestions?
    Problem Solver:
As I mentioned previously, I had previously tried a new bulb behind the control panel and it didn't work. I tried again, but first I unplugged the refrigerator, and then installed the new bulb. And when I plugged the refrigerator back in, the light worked!
I am not sure why unplugging the refrigerator before installing the new bulb worked, but it did.
Darrell
Posted on Sep 11, 2008
    Problem Solver:
I unplugged the refrigerator before installing the new bulb.
Darrell
dccrane1952@gmail.com
Why won't interior lights go off
Bad door switch. Replace it or just ignore it. Use LED light so it will not produce heat in the frig.
May 03, 2014 | LG Refrigerators
Lights out..White box is clicking in back base of frig
sounds like the relay box on compressor . . you can repl the relay . it's not a hard job .. and its lso a very common problem on many frig's . ****
Jan 04, 2010 | Refrigerators
The lights on the Ice and Water Dispenser flash
On left top side of door, remove cap and disconnect wire. This will turn off the control board on front of fridge and fridge will still run. Then follow this link - http://www.liny.net/MaytagIce2O.htm - click on frig picture at right and you will get step by step instructions with parts and tools you may need costing around $20.00 for a do it yourself fix.
Aug 19, 2009 | Maytag MFI2568AE Side by Side French Door...
GE refrigerator tfx27zp or 25zp or 22zp not sure.
The drip pan is located under the front of the frig.
FIX
open both doors, remove the panel that is across the bottom of the fridge( there are release tabs over the left and right front corner areas close to the hing sides
after removing the panel you should see a tray that slides on rails under the fridge
remove the panel and inspect to see (use a flash light)if you can see the drain tube
I believe your drain tube is freezing up somewhere inside the frig
If you can determine where this drain tube fishes up through the back inside wall of the frig
remove all of the trays and observe the back panels there should be some type of collector tray
near the frig light Some models have a hot bulb to do the defrost
I suggest that you tun frig off with both doors open take a hair dryer and blow hot air where you think the drain is located to melt any ice and look down in the drain pan to see if it starts draining
Hope this helps
Good luck ( ps cal ge customer service and give model number I bet they have a design poblem
If they do they may have a work around
God Luck
Jan 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
INTERIOR FRIG LIGHT
replace the switch before the seal, nothing wrong with gasket., you may need to raise the refrig door a bit by , remove the door and install a small spacer to raise the door slightly for better contact
Oct 22, 2008 | Frigidaire FRT21H8 Top Freezer...
Viking all refrigerator
I just started having the same problem with my 48" frig/ freezer Viking Designer series 2 years old- this has been a hot summer, we were not home much and the AC in the house was set higher 78 degrees so the frig I guess had to work a bit more - when I open the door to the frig water droplets acually run down the interior of the door and the box insde is always damp - I also have stress cracks in the interior shell of the frig - repairman is trying to get Viking to fix it- it has been a year now and it still is not fixed- the stress cracks were caused by improper insulation application to the inside of the frig according to the repair people- Also my handles have pealed - like the stainless steel is not really stainless steel - Any ways could the temp in the house changed - does not mean the frig should not work well - For what it costs, I expected better
Sep 11, 2008 | Viking 42 in Built In Professional...
Beeping sound
ok the only other option the latch located in the fridge has a loose wire which need to repaired by a fridge tec but also if the fridge seems like its not getting cold the thermostack that make the fridge cold may be malfunction
any how it needs repair
Jul 07, 2008 | GE Profile¿ Arctica® Energy...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
362 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
