Cadet wall heater
I have a small Cadet wall heater. Both fans work normally. None of the heating elements heat. What could cause this?
  • Anonymous Oct 27, 2008
    Both fans work but no heat. Cadet model CT402
Since I don't know what model of heater you have there might be a reset button to reset or an over temp switch (button sensor with 2 wires going to it) that needs to be replaced. You might check the recall list to see if this one has been recalled and should not be used.
Posted on Oct 20, 2008
Fan works but no heat
look to see if the safety fuse is open you can do that by using a continuity test on the heating element.
Feb 12, 2015 | Cadet EnergyPlus 1600 watt 120/240 Volt...
IS IT NORMAL FOR THE FUSE TO BLOW WHEN A HEATING ELEMENT DIES IN THE FAN HEATER IN MY ELECTRRLUX COOKER?
The heating element is shorting out and causing it to blow the fuse
Aug 25, 2014 | Ovens
I am an electrical contractor of 20 yrs in spokane, Wa. I have used cadet heaters for most of that time. I have an apartment that I built and have rented out that is heated only by cadet heaters. In the...
i am also an electrician. we have had the same problems on our properties.the motor goes out which in turn keeps the element on and gets hot and burns up, setting a small fire. more smoke than fire. cadet needs to put a safety cut out so that when you lose the fan it shuts the element off and the other way around as well.
these are dangerous and will be replacing 100's of them
Jan 24, 2011 | Cadet Manufacturing Com-Pak Max CM202...
Only the low setting works for a little while. heat stops but fans will still run.If i turn up higher nothing, not even the fan. Heater has been cleaned and has a new thermostat swicth. Any help wuold be...
Two things come to mind here, one is the over heat protection is tripped and preventing the element from coming on, second is a bad high heat element. You can ring these out with a volt ohm meter and check both, the element if good rings out as a dead short, the over heat protection should be normally closed which means it to rings out as dead short. If it rings out open then it is tripped. some of these can be reset and most only need to be replaced. So check these items out and good luck.
Dec 27, 2010 | Marley CWH3408 Electric Wall Mounted Panel...
FAN IS BLOWING BUT NO HEAT
hello,
this means that the heater of your cadet have been disconnect from it position or it has gone bad
please note this, that the heater is call element technically if you to get a replacement for it
what you have to do from here to fix up cadet is that unscrew your heart with the basic tools trace the maize i.e the wire down fan then trace the wire from the fan to the element it's always white in colour if it's properly connected from it position then you have to passive it if smiley borne meaning that it has gone bad then it will need replacement,
but if it is disconnected then you will have to do the fixing you self by peaking up the loss wire and fix it up back to the position
thank you and thanks for using fixya.
May 03, 2010 | Cadet Manufacturing 67507 Heater
My cadet c202 heater is running the fan is blowing cold air but no heat, is it the thermostat or heating elements or both???or ?????
I work in a motel and replace these heaters quite often, Cadet C202, a 240v 2000 watt wall heater. Most of the time when they blow cold air it's because the heating element is broken. First turn off the circuit breaker, then remove the heater from the wall. If you take out three screws, slide the top cover off, bend the two little tabs and take out the heating element, you can examine it and usually you will find a place where it is broken, it's like a big spring. Replacement elements can be ordered from online stores such as reliableparts.com Be very careful, 240 VAC is very dangerous! <!-- from fixya rte -->
Dec 31, 2009 | Cadet Manufacturing 67507 Heater
No heat
The element above the fan has brobably gone bad. you can take the grill off of the wall and inspect the coils for breaks with a flashlight. if you do see a break in the coils then the heater is toast.
Oct 05, 2008 | Cadet Manufacturing 67508 Coil / Ribbon...
Heating element isn't working
Sounds like the heating element isn't getting current. If you have a continuity checker or ohm meter, test the element - isolated from the fan and/or switches. If that passes, look for a thermal fuse that looks like a 22-caliber bullet. See if it passes current. Then check the function of the switch, thermostat, and any safety cut-outs like tip-over switches.
Mar 08, 2008 | AdobeAir WH20 Wall Hugger Compact Heater
Electric Heater Coils Always On
i suggest that the thermostat or the switch is at fault, contacts may be stuck. hope this helps
Jan 16, 2007 | Sanyo STW0923H2 Thru-Wall/Window Air...
Heating & Cooling Logo
602 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
