Question about Estate TAWX700JQ Top Load Washer
Small earrings fell into holes on bottom
I had a small pair of earrings go through a wash cycle and must have fallen into the holes on the bottom of this washer. Any ideas on how to look inside there to find them. I can't even figure out how to take the agitator out. I can't figure out any way to remove the front of the washer either. Any suggesstions please!!!
    Genius:
  • 1,028 Answers
If they fell through those small holes doubt you'll find them something that small would probably be pumped out and down the drain ..if you haven't used washer since may be lucky enough to find them in pump but doubt it pump is pretty strong and can handle almost anything except socks and thongs
Posted on Sep 11, 2008
Hobart dishwasher making loud grinding noise in wash cycle
suspect you have something in the wash pump.that has got through the filter or when you cleaned base filter it dropped down the hole,when you had the filter out,could be a small piece of glass or a chip of a cup, if you also think the same ,suggest search on u tube REMOVING OBJECT FROM A HOBART WASH PUMP or
removing objects from a dish washer pump, or pull mains plug out gain access to wash pump, screwdriver in back pump shaft ,turn and you will fill if there is something in pump, some times you can vac out through base filter using a wet vac.
Nov 23, 2016 | Hobart Dishwashers
Whirlpool wtw7300xw2 washer leaking from bottom
check for cracked pump hose/ loose hose, leaking pump, small tube up to water level control
if the water is grey or whitish then it could have water in the gear box from a failed shaft seal
Apr 03, 2016 | Whirlpool Washing Machines
NTW5400TQ
I just had that problem. The repairman pulled the front off the machine and found a small nail that had fallen through the holes in the washer tub. I didn't watch him do this, so I don't know where inside the machine it was, but he found it right away. Hope this helps.
Oct 14, 2012 | Amana NTW5400TQ Top Load Washer
Tub thumps after nail wedges through small hole bottom and stops tub
You could have an unbalanced tub or the piece is rotating around in the outer tub and making the noise. Contact a professional to have the machine taken apart if the noise continues.
Jul 28, 2012 | Frigidaire FEX831CS Top Load Stacked...
Small socket fell into spark plug hole what do i need to do
use a screwdriver type extendable magnet. it should be flexible enough. If it hasn't fallen into the motor.
Nov 10, 2011 | 1998 Ford Expedition
I dropped my ps3 and a piece fell from the internet slot in the back of the ps3 it looks like a earring what should i do?
I would say if the CAT5 cable still locks in and it gets a connection still don't worry about it. I do repairs on the consoles and I can't think of what could have fallen off. There is a small black square piece that goes around the outer edge, but that's just to fill in the gaps.
Feb 21, 2011 | Video Game Consoles & Games
Kudm01TJWH0 dishwasher is EXTREMELY slow draining. Plugging the drain into the disposal builds pressure (10PSI?), but no volume. Any ideas?
The bottom area of all dishwashers have the drain holes and pump which evacuate the water and debris. Remove the bottom tray and reach in and feel around. You may discover that some small items like corncob holders have fallen into the drain holes...If the drain holes are not blocked or clogged, the pump may be weak or defective. Check for debris first, if you find nothing blocking the little drain holes, call a repair agent who may need to get under the wash basin area by removing the washer from the cabinetry.
Oct 08, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Similar problem
That would be the thread guide. You need a small allen wrench to put this whole thing back on. There is a hole in the right side,looks like a hole, it's blackish, but is for allen wrench. The curved metal piece slides up into a tiny hole from the bottom near where needle enters then slide whole thing back on machine and tighten with allen wrench.
Jun 29, 2009 | Brother XL-5340 Mechanical Sewing Machine
Won't Spin
CHECK TO SEE IF SMALL CLIP ON BOTTOM OF PULLEY HAS FALLEN OFF. IF CLIP FELL OFF, THE PULLEY MIGHT OF SLIDE DOWN AND MOTOR SHAFT IF SPINNING. PUSH PULLEY UP AND ON END OF SHAFT ARE NOTCHES WHERE CLIP SLIDES ON. GE RECOMMENDS YOU REPLACE IT. MACHINE NOT LEVEL OR CLOTHES NOT BALANCED PROPERLY CAN CAUSE CLIP TO FALL OFF. HOPEFULLY THIS INFO HELPS.
Mar 17, 2009 | GE Profile WPRE6100G Top Load Washer
Errant earring
assuming this has long since been dealt with, but if its not in the rubber gasket at the front of the machine, take off the bottom panel at the front, there is a small pump there that drains the unit. It may be trapped in there. You can use pliers or vice grips to remove the couplers holding the hoses on and a screwdriver to remove it.
Jan 27, 2009 | Frigidaire FWTBB30DS Front Load Washer
Estate TAWX700JQ Top Load Washer Logo
169 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
