Question about JVC TH-A30 System
System unresponsive when modes are switched
I have a JVC Home theater system model #THA30 The disc tray does not open for playing cd's or dvd's. The radio works fine and the Aux function works ok also. I unplugged the unit for two hours and the disc tray would open but after turning the unit off or changing from dvd to radio it stops working again. Thanks in advance H.L. Allen
    Novelist:
  • 130 Answers
Arnt they seperate things? ive seen some systems that dont function if thery are not in that mode. If its in DVD mode nothing on the DVD works, if its in the radio mode maybe the power changes over to the tunner only? you cant play both at once maybe their idea. Will things work when its in the cd mode? Is the unit staying cool?
Posted on Apr 13, 2006
  • Tyler Ingle Apr 02, 2014
    Yes it also has a video, and sat mode but I also dont have a remote for it, but iam not sure I have all the rca cables hooked up right what are the blue,green and red plugins for? Does the s-video cord need to be pluged in?
    President:
  • 3,130 Answers
Sounds like there may be a glitch in the microprocesor. Make sure when you unplug it that you leave it along for a few days and is there any type of clock or standby batterys in it take them out as well. If that dosent correct the problem your gonna need a service manual to trace the switch pulse to see if the units Switch matrix lines are low or lost because of a faulty micro or a bad componet like a small caps they install on the matrix to keep noise off them. Hard one to call with out seeing unit and analizing unit Good Luck
Posted on Apr 12, 2006
  • Larry  Dillon
    Larry Dillon Apr 14, 2006
    no bower I dont think thats what there saying as far as i can understand that When there in cd mode the door wont open
SOURCE:
How to reset DVD VCR?
put into dvd mode with no disc in tray turn on and hold stop button 5 seconds this will reset to factory video/audio mode
May 11, 2012 | Insignia NS-H3005 Theater System
How to convert the my jvc dvd player to ntsc to pal or vise versa, coz i used old tv so i need to change it . tnx my jvc model is xv-tha30 dvd cinema system
You have to use an external device to convert NTSC to PAL or vis versa. The device cost between 175 to 250 $. I think you can buy a small new generation multi system TV for that price !!!!.
If you still want to buy click on the below link.
http://www.converters.tv/signals/ntsc_to_pal.html
Mar 18, 2011 | JVC TH-A30 System
I am getting the locked display
Hi Blackhawk,
This sounds like you've accidentally set the "tray lock" feature.
You can set this to stop unwanted tray ejections:
I hope this solves your problem..
Warm Regards
Mike
Nov 28, 2009 | JVC TH-M303 System
JVC XV-THC20 CARTIRDGE # 1 BROKE
Mechanism needs repaired and retimed. Only option.
Nov 22, 2009 | JVC TH-C20 System
JVC UX S77 my 5 disc cd says "tray err". It won't open or play.
it sounds like the tray has come off the guides a comon problem with kids pushing the tray in rather than pressing the button. if the teeth on the track are ok then it is just a case of opening it up and putting the tray back
May 16, 2009 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
How do i unlock a jvc home stereo
On the unit, press the stop button and the cd eject button at the same time. The screen will say locked still. Release them and press them together again at the same time. The screen will now read unlocked. You can then eject the cd.
Oct 15, 2008 | JVC TH-C60 System
CD player ate a CD!!
I fixed the same issue by forcibly pulling individual trays to their open position.  I removed the casing to gain better access (tons of screws) but you can probably gain clear access to the shelfs without removing the casing if you have good needlenose plyers.  I found a stuck CD within one of shelfs, wedged WITHIN the moving components of the shelf.  It works perfectly now.
Aug 01, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
How to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Jan 06, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
Tempremental playing dvds
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
Feb 27, 2007 | JVC TH-A75R System
JVC TH-A30 System Logo
207 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
