Question about Goldstar MA-1011 Microwave Oven
Quit working I was using the microwave when everything quit working. No light, no power, nothing. I looked in the back of the mirowave and there was a whole lot of lint/dust covering the intake (I guess that is what it is). Is there anything that I can do or should I consider this microwave a boat anchor now?
  • 58 Answers
Check the fuse, if that dont work, then go fishing.
Posted on Sep 11, 2008
I have a mh1150xm microwave and changed the cooktop lightbulb. Still no light. A tech came and said that need to change whole control board. Is this true. Everything is working fine exept the light
I take it you did replace with a bulb designed to withstand heat.check the filament of bulb first these sometimes get damaged in transit.if the microwave is coming on then it won't be the fuse.if the bulb looks okay(you can check using another) finally inspect the door latch and the bulb housing and wiring to it.Sometimes door latch hole can get debris into the mechanism.cost of panel via engineer can cost quite abit..is it still in warranty? Price compare the estimation against buying new replacement.
Feb 09, 2015 | Whirlpool MH1150XMQ Microwave Oven
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
Mirowave wont start
I assume from your description that you can set power and time but nothing kicks in when you press start?? This could be a control panel fault but may be a problem with the door lock/switches. Check that the spring on the door hooks is ok, just lift it up and check it returns to down position by itself. If the microswitches do not make properly when the door is closed the m/w will not start because it assumes the door is open. A microwave (even when switched off) can be storing a high voltage so unless you are trained I would suggest you get an expert to take a look. BSH is Neff service division 0844 872 8999, they offer a one off repair plan, which covers your first repair and then any further repairs for a year. You can pay monthly by DD to spread the cost. (This may be age related so as yours m/w is nearly 10years old, it may not be eligible).
Hope this helps.
Mar 21, 2013 | Neff Microwave Ovens
I went to use my mirowave & it is completely gone. I pushed every button that I could & nothing happens. What should I do
first check the breaker in the electrical panel. your microwave should be on a circuit with nothing else. Depending on when the house was constructed. If the breaker is tripped turn it off and back on. If the microwave is plugged into a gfic outlet check to see if the receptacle needs reset. There will be a reset button on the receptacle. Their may be a orange light on the receptacle.
Jan 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave wont work on generator power!
PLEASE CHECK THE POWER CONSUMPTION ON THE APPLIANCE i think it might be a lot more than ur gen set can supply
Jul 08, 2009 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
My touchpad on my microwave quit working.
may i please ask you how old is the machine? what you need to do is open it up and have a very good look at the pads. check for ware and tare. give the contacts a clean. may i please ask are you pressing the pads two hard? please check the light. it may just need to re new it. if you have a meter. check the circuit board to see if it is getting any current. also you like to change the fuse. check that you are getting the correct power? from the mains cable
May 04, 2009 | Kenmore Microwave Ovens
No heat but everything else works
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 17, 2009 | Whirlpool MH7140XF Microwave Oven
Goldstar MA-1011 Microwave Oven Logo
110 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
SHARCNET-USA
SHARCNET-USA
Mike
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
