Question about Zenith Televison & Video
Unable to get stations 17 and 45(UHF)on Zenith model SM2067BT
Unable to get stations 17 and 45(UHF)on Zenith TV model SM2067BT with my universal remote. Local stations ok.
  • 41 Answers
The problem is station 17 1nd 45 is not yet programmed to your tv...
Posted on Sep 11, 2008
Universal Remote Controll Codes for a Zenith TV
These are the codes for Zenith TV: 0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Aug 04, 2012 | Big Button TV Universal Remote
I have a Zenith SM2067BT TV set. When I turn on the TV, it is evidently turned to the wrong channel. It comes on channel 2 instead of three. When I try to change the channel to 3,it reads aux or aux seq. I...
you must be on a box, put your tv on channel 2or3 then with the control for the bx channel up-down if not then just do channel up-down manualy
Feb 14, 2010 | Zenith B25A02Z TV
Since the digital switchover, I have lost channels, despite re running the setup and tuning. Any suggestions as to why this is happening?
I have a similar issue. When the digital switch happened here some of the local TV stations changed frequencies from UHF to VHF. I do not have a VHF antenna so I am unable to receive these channels. I do have a great UHF antenna, but it will not receive VHF. The fix is of course is a new UHF/VHF antenna. I am 50 miles away from the TV transmitters.
This may or may not be your problem. I hope this is helpful to you.
Bob
Nov 08, 2009 | JVC LT42P789 42 in. LCD TV
Sk-32h240s unable to get all local channels thru ant. only what whould be the formally vhf channels, not uhf.
UHF needs a UHF antenna most all channel antennas do not work good on UHF,
Try the set at a friends house that does get those channels. UHF is harder to get and that is why a UHF only antenna is needed by most people. Lots of antennas are junk do a search and you will find the 8 bay C/M is rated the best by a large margin.
A good antenna amp at the antenna is also needed it should be a low noise one. A search will show the ones that work best.
The Gov. as much as lied to us and the TV Stations the type of digital they forced on us is the wrong one and millions of people even with a great antenna have lost TV.
Oct 25, 2009 | Westinghouse SK-32H240S Television
I am unable to figure out how to remove SAP from 2 of my stations when I run the VCR through the Zenith TV. This is a relatively new problem. All the other channels I record are okay. I downloaded...
LEAVE TV UNPLUGGED OVERNIGHT TO RESET ITSELF. IT SHOULD BE BACK TO NORMAL AFTER POWER DRAINS FROM POWER SUPPLY. THAN GO INTO YOUR MENU SETTINGS AND TURN SAP OFF
Apr 19, 2009 | Samsung Televison & Video
Tv WILL NOT GO PAST CHANNEL 18 AND THE REMOTE IS UNIVERSAL AND WILL NOT PASS THESE STATIONS EITHER.cAN BRING UP MENU BUT CAN'T GET ANY FURTHER THAN THAT. wHAT CAN i DO TO GET PAST THIS?
There's a setting in the TV to be able to switch between VHF and UHF. VHF is limited to channels 18 and below (if I remember correctly). Look for a switch or setting on the TV to change it to UHF. Could be a setting in TV menu or a physical switch on the TV.
Apr 06, 2009 | Televison & Video
Zenith sm2067bt tv
the tv is just okey only that it has a failt with tuner stage, but never the less, take your tv to a tech, who will contact, assistance.
www.freelists.org/archive/techassist/01
with no time your tv will be okey
Jan 25, 2009 | Zenith B25A02Z TV
Sanyo ds 31350 tv
Hi there!
Assuming that you tried to tune stations onto the UHF bandwidth and received nothing,Commonly the tuner box is probably at fault and needs replacement. The VHF and UHF signals are split inside the tuner so if you receive VHF fine then UHF should as well unless faulty of course. Some circuits require an external IC to do the switching, but more on the older models. Regards and good luck, JUS004
Apr 02, 2008 | Televison & Video
VHF stations WILL NOT display. UHF stations WILL display. Have tried both the remote and the controls on the TV. What is the solution?
a no ufh channels would be a setting in the menu, but when your vhf channels go, the problem is typically the tuner itself, or the band switching ic. could be either. you will need a schematic to know what voltage is supposed to be on the pins.
Jan 24, 2007 | Zenith B25A10Z 25" TV
Televison & Video Logo
87 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
