Question about Kenmore 24032\24036 Top Load Washer
KENMORE 110 -LETS WATER IN..DOES NOT SPIN
HELLO...I HAVE A KENMORE 110 WASHER, LETS WATER IN BUT DOES NOT SPIN.
PLEASE HELP.
SYLVIA
  • 5 more comments
  • Jimmybobbill Sep 13, 2008
    I have the same problem with the same machine. I checked my lid switch and that turned out to be ok. Now what?
  • Anonymous Sep 15, 2008
    My 110 washer will agitate for about 9 seconds and then stops. It will rinse and spin fine but will not agitate on the clean cycle. Please help.
  • kaak Sep 17, 2008
    I HAVE THE SAME PROBLEM AND I THINK SMALL CLOTHES FELL INTO THE SIDE OF THE SPINNING BASKET AND ITS ENCL0SURE.I OPENED THE BACK COVER AND I SAW SOME CLOTHES BUT I DO NOT KNOW HOW TO GET THEM OUT. ANY HELP?
  • g_mubay Oct 22, 2008
    I have a 2 year old Telmann toploader washing machine - Tel6tl. After setting it up for wash it just displays an E2 and does not start. What may be the problem with it? Please help.
  • HETAHRD Nov 10, 2008
    i HAVE SAMILAR PROBLEM BUT DISPLAYS E1 ANY IDEA'S
  • jkimmccue Dec 29, 2008
    My Kenmore 110 will drain but does not agitate or spin.
  • Dan Sharpe
    Dan Sharpe May 11, 2010
    Does it agitate? If so, when it should be spinning does the motor run, but the basket just won't turn?
  • 750 Answers
Hello Sylvia,
You said,
HELLO...I HAVE A KENMORE 110 WASHER, LETS WATER IN BUT DOES NOT SPIN. PLEASE HELP. SYLVIA
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin.
The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts.
If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed.
As the clutch wears out, it may prevent the unit from spinning well or at all.
If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified
appliance repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor.
For agitation the motor runs in one direction, for spinning and draining, the other.
It's possible for a motor to burn out in one direction and continue to operate in the other.
If this happens, you need to replace the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool®
have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective,
the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem,
you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized.
These components allow the inner tub to spin freely inside the outer tub. When this is the problem,
you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety,
washing machines are made so that they spin only with the lid closed.
The lid switch prevents the spinning action when the lid is up."
Bless You,
Please give me a good rating for the sound advice , before you sign off.
Thank You
Posted on Sep 17, 2008
I have a 2 year old Telman toploader washing machine - Tel6tl. After setting it up for wash it just displays an E2 and does not start. What may be the problem with it? Please help.
Posted on Oct 22, 2008
My Kenmore Washer 110 was not spinning and was agitating very slowly. I replaced the defective lid switch and now am spinning. The agitation is still weak, almost non existent, but the motor is heard as if it were working well. The machine is supposed to be dual action, if that means anything.
Posted on Oct 21, 2008
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
Washer stops in rinse cycle
your contacts swithces for rinse cycle inside timer could be burned or bad..very model I will locate part number
Dec 15, 2007 | Washing Machines
During the spin cycle water pours continuously like fill cycle
This problem is commonly attributed to either a water inlet valve leaking by, or a pressure switch malfunction. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
I've included parts sources (if required) and how to repair each problem. If you have any questions, please post back and let me know. I hope this information is helpful to you.
Mar 19, 2010 | Washing Machines
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Washer wont spin or take out the water
Hi 1st remove cabinet by removing 2 screws securing the console to the cabinet top.pry clips at corners and remove .you should now be able to pull cabinet towards you and separate it from chasis .motor /pump at center front bottom.plastic plug on right, wiggle that plug with washer in spin probably bad connection in plug.red/black wire Hope this helps please rate my solution. :)
Jun 26, 2009 | Kenmore 24032\24036 Top Load Washer
Machine agitates but doesnt spin or pump out water
you will need lid switch 285671.. whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
May 26, 2009 | Washing Machines
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer drains but won't spin.
Sounds like the motor coupling has broken, fairly inexpensive part but does require some finesse to install. let me know if you decide to attempt it.
Oct 15, 2007 | Kenmore 15864/15862 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
431 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
