Question about Canon Office Equipment & Supplies
Canon 7020 printer settings. Staple function grayed out.
5 Suggested Answers
Kevin Hayes
  • 167 Answers
SOURCE: staple function
You do n ot need to enter the Service Tech code to ajust finishers. In fact that code should rarely be entered.
Is the option available while copying?
If it in the driver, select the greyed out option and let the driver inform you of the problem/setting.
Has the finisher been identified in the "instaled options" tab of the driver?
Normally, the driver or panel will indicate what the conflict is if any. If all these have been set correctly, contact whomever installed this finisher and have them do it properly.
Posted on May 27, 2008
  • 47 Answers
SOURCE: Staple problem
Assuming your copier actually has a stapler, I would think you would have checked that, then the driver is probably not set up to recognize the stapler.
click Start->control panel>printers and faxes>(your printer name)>printer>properties>device settings. There should be a button labeled something like "auto configure". click that and it should discover all the options attached to your copier. When it is done click on whtever it asks youto accept and click apply. The picture to the left should also look exactly like your copier. (Sometimes the auto configure fails in which case you will have to set all the options manually, you can use the image as a guide until it looks right. )
Posted on Jul 18, 2008
SOURCE: Pgm to staple with a Canon ImageRunner 5000
Canon handles it as PJL comments.
Google the string "PJL COMMENT CANPJL"
Posted on Oct 12, 2008
muleskinner2
  • 270 Answers
SOURCE: Environment: Windows Server 2008 as Print Server.
I believe you have to identify the accesories that are on the copier. I think you go to the printers section of the control panel on Windows. Right click the copier, select properties, then device settings. Look to see if you can change any of the options. If not you may have to reinstall the print drivers. Hope this helps.
Posted on Feb 02, 2011
Problems &Solution of Error E530 of model ir3300
for E000530-0000 error, Just go to Aditional Functions - Adjustment and Cleaning - Staple Function and OFF it.
Machine will work but finisher may not.
Thankyou
Aug 24, 2012 | Canon Office Equipment & Supplies
Can I print on both sides of the page
Here are the instructions for duplex printing.
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
1. Open the printer driver setup window, and check the Duplex Printing check box on the Page Setup tab.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note
sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper or Photo Paper Plus Double Sided is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
You can download a users manual for your MX310 at
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
Please rate this solution. Thanks.
Sep 27, 2011 | Canon PIXMA MX310 All-In-One Printer
Environment: Windows Server 2008 as Print Server. Canon Copiers iR3570/iR4570. The Canon Driver Information Assist Service is installed on the server. This allows the server to communicate to the...
Jan 27, 2011 | Canon imageRUNNER C3200 Copier
Canon Imagerunner 3035. refilled staples, but copier thinks empty
frst: did you set the staples according to the instructions?
second: try the few times remove and insert staple cartridge in and out, until you heare the loading clicks.
third: check the staple holder for damadges or residuals of staples.
Jul 31, 2010 | Canon imageRUNNER 3035 Black and White...
Finisher setting will not work
touch the additional functions key then touch custom settings scrolll till you find limited function mode touch it then turn limited function off turn copier off then on this should turn the finisher back on unless the finisher has an error
Sep 25, 2009 | Canon imageRUNNER 5000 Copier
Aug 25, 2008 | Canon imageRUNNER 5570 Copier
Staple problem
Are you sure you have the correct sorter, they come with diff. options. the same model comes w/wo staples- w/wo book binding etc.
For example : w staples may be an AOor A1 model
wo maybe an AS or B1 model
Jul 17, 2008 | Sharp AR-407 Copier
Staple function is grayed out - how do you turn it on.
Apr 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
DCP 7020
If you are using non brother toner then that's the problem, if not it is the drum unit.
Dec 19, 2007 | Brother DCP-7020 All-In-One Laser Printer
167 people viewed this question
old marine
old marine
