Lock folder on External HDD
How to lock folder or file on External HDD?
hope the folder or file could not be opened from other pc also.
    Novelist:
  • 116 Answers
The best way is to use an encryption software. This will encrypt the folder and lock it via a password no matter what user/system tries to access it. WinRAR, and WinZIP also offers some encryption techniques. The best I've used was actually an updated windows folder encryption program.
If you're running a higher version of windows vista (business or ultimate) you could use the software that comes with windows to encrypt the folders. Though, I'd suggest looking around at different applications on the internet. www.google.com is the best place to start. If you have any questions on certain types of applications I can help with that later on. However, I'd suggest at least a 128bit encryption application as the encryption is very difficult to break. :)
Hope this helps bud!
Posted on Sep 11, 2008
Folder dissapear only some open file are ther and drive show 80 % full
Most probably your PC & external HDD is infected with dangerous objects/files eg. virus, malwares, etc... which resulted your folders & files atributes changed to "hidden".
Do a thorough Virus/Malware scan for the PC & External HDD, to removed the "dangerous object/files"
Refer to this thread how to recover your "hidden" folder/files @ Reset System and Hidden Attributes for Files or Folders Caused by Virus
Hope it helps
Apr 29, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I installed a second WD My Book, after the first one inexplicably filled up too quickly. Now the second one has inexplicably filled up also. What could be causing this?
The most logical reason for this problem to occur is because you're storing too many files in the ROOT of the external hard disk drive (HDD). The Windows file system can only manage a limited number of files (about 500) in the root of ANY drive. It is better to store those files in a FOLDER on the drive; Windows can manage an infinite number of files IF you store them inside a folder. Let's see if we can resolve this step-by-step:
1. Open Windows Explorer and navigate to the external HDD (drive E:, drive F:, drive G:,or whatever letter it has on your system).
2. If the external HDD does NOT have a name (such as "WDMyBook01", or something else easy to remember), RIGHT-CLICK the letter of the external HDD; Windows will give you the option of creating a NAME for the external HDD.
3. Create a name for the external HDD, you can use any combination of letters or numbers, but NOT MORE than 11 characters in length. By creating a distinct name for your external HDD, you'll have an easier time remembering which MyBook drive has certain files on it. Be sure to do this for BOTH external HDDs.
4. Next, create a new folder in the ROOT of the external HDD; give it a simple SHORT name, such as "Folder01" (no quotes).
5. MOVE ALL OF YOUR FILES from the ROOT of the external HDD into the new folder you just created.
6. In the future, put ALL your files into a folder on the external HDD, so you can avoid experiencing this problem again.
7. As you've probably already guessed, it is also a good idea to avoid putting more than 500 files into the root of ANY HDD. SOME files MUST be stored in the root, because that is where Windows expects to see them, but don't add any of YOUR files, the ones you create or download, into the root of the drive.
8. This numerical limit also applies to USB flash drives and other storage devices. You avoid this problem the same way, by creating folders in the root of the drive and storing all files inside a folder.
Good luck with this; let us know if you have any questions.
Apr 26, 2011 | Western Digital My Book Essential 1TB...
How to delete files and folders off my IOMEGA 1TB EXTERNAL HARD DRIVE
you can just connect your hard drive to your pc and open the folder from my computer and select the folders that you want to delete and press the delete key in your keyboard. then the computer will ask you that " you want to delete the selected files and folders?" then you press ok. it will deleted
Sep 14, 2010 | Iomega HDD External Desktop (32660) 80 GB...
How can I transfer my files from this drive to my hard drive
juast go to folowing steps
1 conact your Extrnal HDD to you PC
2 u will find your External HDD in my computer open that drive then copy all your files wiche you want to copy from External to PC
3 meak new folder in your PC and just past all files in to new folder
4 then chack your files will in your pc
May 11, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Formatting an external hard drive
Open up Folder Options\View\Show Hidden Files and Folders. Return to your Toshiba HDD. Do you see an hidden files? If so, try to delete them. You may have to change the Properties of these Folders\Files in order to delete them. BE WARNED, removing or deleting any folders or files that Toshiba placed in there could have negative affects on the way your external HDD runs.
Mar 18, 2010 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Buffalo 320Gb external HDD says The folder is empty but in properties it consist of 128Gb of files. i need my files how can i fix this up?
NOTE:
-First off, use a external hard drive for back ups only.
Never allow this to be anything but a copy from you PC.
TWO RECOMENDATION:
Option I.
Go to your Control Panel
Select folder options.
Select the View tab.
Select "Show hidden files and folders.
Option 2.
GOTO:
www.recuva.com
Just choose a drive,
Then click the Scan button this will begin recovery of all data on the drive you select.
Hope this Tip helps you.
From someone who has lost a lot of Data.
R/
David
Feb 19, 2010 | Buffalo Technology 320GB MINISTATION TURBO...
Folder Lock Opens empty Locker - Should not be empty.
try usin it on another computer,please scan for viruses
Feb 04, 2010 | Computers & Internet
Can't access files on external hard drive
Hi All had the same prob with my external drive and used a program called Easy recovery professional it worked for me .hope this works
Dec 27, 2008 | Western Digital Passport WDXML800UE...
Hp nx9110
Try removing your HDD very carefully. Check configuartion and type you need to purchase an external USB converter adapter depending on your HDD type then open it in another PC you can basically save the data there. To remove the driver lock you may try opening the BIOS by f8 or f10 during reboot and disable driver lock there if it asks for a pass key and you dont have it then you can try the first option of saving the file and reformating your hard Disk. Hope this helps.
May 29, 2008 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
