Question about HP Computers & Internet
How to connect speakers and get volume - HP Computers & Internet
    President:
  • 1,257 Answers
Firsty install the drivers for your system through the motherboard cd or download the drivers from manufactures website...then You have to connect the speaker jack to cpu in the green slot......and that's it.
Posted on Sep 11, 2008
The volume of my model's volume only goes up to 40...is there a way to increase the volume?
Sometimes you can connect a lower ohm speakers. However you must NOT go lower than the amp can take. For example if the amp has 8ohm as the lowest for it you can go to 8ohm speakers, if it has 16ohm speakers connected, but must connect 6ohm speakers. If the amp allows 6ohm than you can connect 6ohm speakers. Changing from higher level speakers to lower level ones will make the volume louder. But you must not connect ones lower than the rating of the amp.
The only other way is if there is something wrong with the amp and that it won't go higher due to a fault.
Oct 27, 2017 | The Audio Players & Recorders
The volume on my iphone 5 is not working
I can safely say you connected your iPhone to a speaker dock sometime in the past.
When connecting an iPhone to a speaker dock, the volume control is set through the speaker and not through the iPhone.
Sometimes after unplugging the iPhone, the iPhone keeps thinking that it's connected and won't let you change the volume through the iPhone.
To fix this - simply plug your iPhone to a speaker dock again and unplug it until you can manage the volume with the iPhone.
Apr 08, 2014 | Apple iPhone 5
Rear speaker volume
Check wire connection to rear speakers and ascertain the speakers are properly grounded. Using a multi-tester, there should be "zero" ohms resistance between the speaker ground and a nearby nut, bolt, or metal component part of the receiver. Get a cheap speaker and splice the test speaker to see if there's sound when radio is "on." If there's sound, but you can't control the volume, then the volume control knob is defective. The volume knob is a potentiometer, which is a variable resister identical in principal to the electronic fuel throttle of your vehicle. If volume is controlled by 2 buttons, then the button's circuit are not connected to the main motherboard.
Nov 28, 2013 | Audio Players & Recorders
Only right side volume working wehn volume is low, when volume is high both sides work but distorted
It may mean that the connection for your left side speakers are loose or they are not connected properly. you can also try plugging the speakers to another music source (ipod, stereo, etc.)
If the same problem happens it is most likely a faulty wiring on the left speakers.
PS - if your computer volume software has the balance option make sure it's in the middle and not set to have output on just the left or the right side.
Hope this helps!
May 12, 2011 | Logitech R-10 Computer Speakers
I just connected my Logitech lS11 speakers. How do I tell my computer that I now have these? When I click on my volume icon in the tool bar to adjust my volume does not work? thank you
Windows does not detect specific models of speakers. I would adjust your Windows volume all the way up and then adjust the sound on your volume knob on speakers. This way the sound volume is easier to adjust on speaker than using the volume control in the toolbar.
Mar 06, 2011 | Logitech LS11 Speaker 2 Speakers
I have a pair of JBL Duet speakers and 1 doesn't work unless the volume is maxed out on the other.
mcdevito75 here, Try to increase the volume from your keyboard, Then adjust the volume at the speakers, there should be only 1 volume control on 1 speaker to control them both, also check your connections at both speakers.
Jul 17, 2010 | JBL Duet Speakers, White Computer Speakers
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
Only one speaker working
Even I have faced the same problem for the past six months.. Today i have fixed only issue with the back jack.. removed slowly and fixed it tightly.. it's works. :)
Oct 06, 2007 | Harman Kardon HK206 Computer Speakers
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
