Question about Panasonic Televison & Video
I have a projection tv and i cant get all of the blue to line up i config. 2 what does this mean
  • josh_cart Sep 11, 2008
    Model # PT-47WX51E
  • Panasonic Master
  • 8,617 Answers
Sounds like the convergence ICs need to be replaced. Please respond to this same post with your model number and I will try to assist you with the problem.
Posted on Sep 11, 2008
  • Sonny Berry
    Sonny Berry Sep 11, 2008
    you will need to replace both convergence ICs they are STK392-110 you can get replacement ICs at the following link with free installation instructions.
    http://servicemanuals.vstore.ca/
The blue projector is out of place i can't make it line up with yellow and red in the menu
U mean ur tv picture look like 3D pictures,colors R,G,B don't line up?This tv have a problems call Convergence,it dead.The tv Convergence board have the 2 convergence ICS and some or all it resistors are dead.These parts on the convergence board must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Red, yellow and blue bars going through the screen, what does this mean and how do I correct it?
U mean ur tv have colors shadows?Colors lines Red,Green,Blue misaligns don't line up to produced a solid picture?U have a 3D pic?All these are cause by a problems known as CONVERGENCE PROBLEMS.Ur tv the convergence board the 2 convergence ICS and some or all it resistors are dead.All these parts on the convergencce board,must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 15, 2010 | Toshiba TP50H50 50" Rear Projection...
52 Inch Zenith TV has red blue and green squiggly lines what is wrong, no picture
I belive that the red light means that it is off and the blue means that its on
Jun 10, 2009 | Zenith D52WLCD 52" Rear Projection...
Cant get the redd green an blue projectors to line up correctly
you need to have the set reconverged,,,call a repairman to come out and reset the colors
Mar 01, 2009 | RCA HD52W56 52" Rear Projection HDTV
Lines on TV Screen
Depends on the TV model, if this is a rear projection TV with CRT lamps, that means that either CRTs are not aligned (fault on convergence board) or one or more CRTs had blown.
Jan 02, 2009 | Televison & Video
Blue rainbows lines
I can help you out because I have circuit details of KP-65WV600but let me know what does it mean of blue rainbow lines?
I would appreciate if you post picture of those blue lines to understand problem of TV.
Thank you.
Nov 24, 2008 | Sony KP-51WS500 51" Rear Projection...
Colors off. blue and yellow not lined up
try to set the convergance if you cant you can adjust the color tubes from inside the tv but have to be very careful to do this. There is actually only 3 colors in the tv red, blue green so I would say your blue and green need lined up
Sep 30, 2008 | Televison & Video
Blue Screen and TV shuts off
Here's a shortcut to what the blinking codes mean.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Strange how some people have 5 blinks. Most with this problem have 8 blinks (like myself)
I still have the blue-flash-then-shutting-off problem.. (8 blinks meaning voltage error) but I did fix the blue lines.. The lines across the screen can be very easily fixed whether they're blue green or red. . No, I mean REALLY easy. Took me longer to get the cover off. Once the front cover is off it takes 10 seconds. This link was also posted recently in one of the posts below as a solution..
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
(My lines didn't look like the ones in the picture mine were several evenly spaced blue arcs)
After some research I believe the flash/shutting off problem means the CRT is going. I've also read that it might be the D-board and I'm not even sure that that is... But If it is indeed the CRT then I'll let you know it's very difficult to find a replacement blue CRT as this part has been discontinued.. but I did eventually find an alternate to an alternate part (yes that's the 3rd alternate !)) online for $256. Here: http://store.tv-repair-service-salinas.com/8-733-649-35.html
If you're bold enough to attempt that then good luck and please let us know if it worked.
Or another alternative is there's a whole lot of Boxing Day sales goin' on right now.
Jul 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Ghost blue cant line up convergence 2lines and blue t on the left of what suppose to be white t
Your Convergence ICs need to be replaced. If you need anything further let me know.
Jan 23, 2008 | Zenith R40W46 40" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
