Question about Avermedia TVPhone98 (61M168CA) Video Capture
Sound fading with lots of hissing; butpictures still okey.
    President:
  • 3,130 Answers
Did this card ever work properly as if it didnt then it wasent installed properly or set up right. If it was working then went bad first try to uninstall and reinstall and if that still has a problem your gonna need another card as far as i know and tryed in the past you cannot get a schematic diagram for these. Good Luck
Posted on Apr 15, 2006
I had the lamp my Sony Bravia X2 replaced last nov 2011. Ithasbeen lots of green andredcolors in tv programs and have tried to change the color barson remote etc butpictures still aren't right. Its or
Unfortunately, this is a very common issue with Sony rear-projection televisions. The optical block fails, causing discoloration, usually blue or green. There was a class-action lawsuit which ended in 2009 regarding many Sony models, including the Bravia X2.
It can't be repaired, at least not for a reasonable amount of money.
The silver lining here is that as recently as 2011, Sony was offering discounts on brand new TVs, to people who called in with their "green blob" issues. It's worth a shot, give Sony a ring at 1-888-476-6972
Nov 09, 2012 | Televison & Video
There is a scratchy sound when the overdrive is engaged. Its not a hiss but a scratchy sound that is noticeable when you hit a cord or note and its fading out
There likely is a component failure. Possibly an electrolytic capacitor. Also low voltage due to failing power adapter or depleted battery would cause this. Do NOT count on LED for battery health..
May 17, 2011 | Keeley TS808 True Bypass Modded Guitar...
Kp 61HS30 TV Had the tv since 2002. been a great tv. Just recently it started making a noise when you turn it on. Noise fades away after about 10 seconds. Noise kind of sounds like a dvd player trying...
If you locate the audio board, check for dried up electrolytic capacitors and dry joints around the output IC itself.
That should fix your fault.
Nov 27, 2010 | Sony KP-61HS30 TV
Hissing and Humming when trying to use the speakers for the tv
The sony manual tells you how to connect to a TV however most of us now watch TV connected to a SKY box. The Scart lead needs to be connected to the Sky box for the sound to work correctly. Ignore the Manual and connect the Scart lead from the DVD Unit directly into you're sky box. It works fine.
Apr 04, 2010 | Sony Audio Players & Recorders
Gas fumes
chech the fuel pressure regulator,its black incolor and has a vacuum line to it.It will be in the fuel rail.start the van and pull off the vacuun line, if fuel comes out its bad.
Feb 01, 2009 | 1999 Oldsmobile Alero
No sound from M-audio BX5a monitor
I have a pair of BX5a monitors hooked up to a video editing suite. One of the monitors is off. They are powered to a working electrical supply. They are driven off a Mackie DFX-6 with a 1/4" unbalanced connection. No blue light on the monitor, no sound or hissing on that...
Jan 31, 2009 | M-Audio BX5a Speaker
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
Magnavox mptv68a
any magnavox controler will work just put in some good batteries . lots retail wholesale stores like walmart carries magnavox tv remotes but make sure its a magnavox.
Apr 10, 2008 | Philips Magnavox 27MS343S 27" TV
Avermedia TVPhone98 (61M168CA) Video Capture Logo
50 people viewed this question
Top Avermedia Televison & Video Experts
Steve Allison
Steve Allison
Alun Cox
Are you an Avermedia Televison and Video Expert? Answer questions, earn points and help others
