Question about Clarion Car Audio & Video
I have a clarion nx501. The micro sd card that has the navigation on it is corrupted. the guys at clarion said that they can't cover this under warranty. please tell me what my options are. i heard that the sd card is only for that specific unit. Thanks for your help
Please read my post here: http://community.crutchfield.com/forums/p/22187/251957.aspx (pasted below).
I hope you bought your unit at a Clarion dealer....
Hi, (Team Crutchfield - please add this to your knowledg-base.)
I'm on my third NX501 (could have been the fourth if not for working directly with Clarion).
The SD Card corruption causes both loss of Navigation and intermittent Sirius start up (it'll never acquire signal).
Your unit needs to use the exact micro sd card it came with forever (it has a permanent serial number).
You have two choices:
1. Get Crutchfield to replace the unit
2. Call Clarion (I suggest this rather than ripping your dash apart over and over).
Here's what to do. Contact:
Ben Kwan
Customer Service Technical Representative
Clarion Corporation of America
800-347-8667 ext 4342
Direct Line: 310-217-4342
Fax: 310-217-4243
Ben will have you send your microsd and rebuild it for you and return it (likely with the firmware upgrade that addresses this issues on another microsd that can also be found here: http://clarion.com/ca/en/support/navigation_updates/NX501Fupdate/index.html).
While you're at it, update the Bluetooth firmware too: http://www.clarion.com/us/en/support/software/NX501/index.html
Once you get the card returned (THIS IS HUGELY IMPORTANT - EVERYONE WITH A Clarion NX501 SHOULD DO THIS!!!), back it up using Naviextras toolbox (the program clarion uses for map updates). You can get it here: https://clarion.naviextras.com/shop/portal/downloads
Once you follow these steps, barring your micosd physically or logically self destructing, you'll have an NX501 that's nearly problem free and backed up just in case that unfortunate corruption reoccurs.
Of Note: Ensure you insert the microsd card with the contacts facing up and do not force anything.
I'm extremely confident this will make a world of difference for you (and anyone suffering the microsd corruption of the Clarion NX501).
Regards,
Marc (mshmovie)
Posted on Sep 03, 2011
I have a similar issue, when updating my BT firmware, I mixed up the mSD cards and started to delete the software off the navigation one. I cancelled it before the entire card was wiped but it now no longer works. I am left with a device.nng and navigation folder on the root of the card and the navigation folder only contains the content and save folders. I am familiar with Igo software and I think there should be some actual program files in the navigation folder. Could anyone post a screen shoot of the contents of their mSD card (root and navigation folders).
Thanks,
Jake
jmarynicz@gmail.com
Posted on Oct 17, 2011
SOURCE:
Why did the screen stop displaying anything?
No idea.
Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
Dec 15, 2015 | Clarion Nx501 6.2" Double-din Navigation...
I have the manual for the Clarion NX501, but it does not tell HOW to set clock.
Page 51 of the manual, under General Setup Menu, is Clock.
Here is where you set time, AM/PM, or 12/24 hour clock,
Nov 02, 2015 | Clarion Car Audio & Video
I have a Clarion 501NX. The Navigation will not work. Was a micro chip supposed to come with it. I looked in the door and no chip was inserted in it. The unit came with a motorhome that I just bought
The small slot is for a MicroSD (storage) card which is not required to be used for operation. I have no experience with this model but here is the link to the 160-page manual which you likely don't have. This may provide enough detail to resolve your problem.
Download manual
Nov 17, 2014 | Clarion NX501 6.2 SINGLE-DIN NAV...
Clarion Max960HD won't read SD card
Just to be clear, you tried SD cards, 2GB or smaller? The unit won't work with higher-capacity SDHC cards.
May 16, 2013 | Clarion Car Audio & Video
Clarion nx501 with hino and password
i hAVE the same exact issue and the 4 digit password to unlock it is the last 4 numbers the HINO trucks V.I.N... they say u only get 3 tries and it locks it and the only way to unlock it is to contact clarion... lick my balls clarion the default password is 0000 and u get 3 tries but just disconnect the power and reconnect the power and BAM... you will be asked to enter a security code all over again...0000 that is your unlock code.
as for the start- up HINO screen... good luck. its called a splash screen and you would have to hack clarions firmware in order to do so and i suppose if you were able to locate the internal hard drive but even then. clarion invested billions to protect their operation systems in their devices. i think the image is burned into the chip where the head unit was sent from a hino dealer brand new in a box directly to clarion's I.T. to have changed cause it comes factory as a clarion boot screen.
you will also notice that the hint clarion nx501 wiring harness is altered so to make work in that truck that only comes with two front speakers.... the rear speaker leads are nowhere to be found; GONE like a new brides panties!.. you also won't have any rya leads ect.. gay gay situation and if u figure out the splash screen change let me know.
peace.
S.D
Jan 16, 2013 | Clarion NX501
HOW TO UNLOCK MY CLARION NX 710
I have the same problem, after disconnect battery connection my Mitsubishi outlander Navigation system Clarion NX710 locked.
I have translated the Japanese Clarion owners manual, it has a from to send with SD card, so they can reset it.
I have tried to open the SD card in a pc. but SD card just showed in a blink and disappeared, so can't open the SD card. if Clarion experts only need to work on SD card to unlock it, so why this SD card can't open and modify they PIN code stored inside?
Any one have any clue?
Dec 10, 2012 | Clarion NX500 Car Video Player
I have an error message coming up on my Clarion NX501 in dash navigation system "Out of Memery" "Requested: 2416555267" "Cache : 0" Navigation will not come up at all....
take the navi card out and stick it in your computer then partition it then update it online with new navi software reinstall the card this should fix your problem
Sep 21, 2011 | Clarion NX501 Car Video Player
Under the find menu several function icons are missing
Has your micro SD card become unseated from the slot? If so, and if you have any navigational maps on the SD card, the icons won't show up on your unit. Remove the micro SD card, wipe the brass contacts with a clean lintfree cloth, re-insert and see if that solves your problem. You might have to go to your map setup screen and choose to show the navigational maps.
Nov 24, 2008 | Garmin eTrex Legend Cx GPS Receiver
Car Audio & Video Logo
6,879 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
