NO POWER MY TV JUST DOESN'T COME ON. IT WAS WORKING AND AS I PUT IN THE TV AERIAL IT JUST POWERED DOWN AND DID NOT *** ON lg 20LS7D, worked fine going on two years, no longer powers on. Nothings changed, but it won't turn on, and the little red/green button has no light anymore
  • Anonymous Dec 24, 2008
    Ours does not respond to anything. The Insignia logo on the front blinks on/off, but that's the only sign of life.
I ended up unplugging both sides of the power cord (from the TV and the wall), waiting five seconds, plugged it back it, and it worked fine.
Posted on Sep 12, 2008
I just turned my digital receiver on & my LG tv & the tv says it's not programmed
Try to unplug from power both the set and the box for several minutes and then power both back up---this will allow both to try to reboot.
Dec 08, 2012 | LG 32LG30 32 in. LCD HDTV
Aerial Socket on LG TV ceased working
Most likely the TV has a burned out receiver board.
May 24, 2017 | LG Televison & Video
No TV signal
try a different aerial if that doesnt work do a factory reset and then redo your first time installation
Jan 02, 2010 | Televison & Video
TV works fine on analogue however won't work on digital even when re scanning. When it happened the television froze and then wouldn't work. Now all is has is "no channel available. Please scan" do you...
Power the TV off and uplug from the mains, now remove the aerial, now press the standby button the TV, now plug the mains back in and switch to a DTV channel, wait 5 secs and then put the aerial back in whilst still on that channel, now rescan.
If that didn't work, reset the TV to factory defaults and rescan again.
Thanks
Oct 08, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Black screen on a 20ls7d LCD TV
I work at CNN Have had 6 of these monitors go out in as many months. Take out the power supply and change the 2 exploded 680u capacitors. They're being overheated by the underrated MOSFETs on the reverse side of the board. I'm looking for some substitute MOSFETs that handle power better; but replacing the caps will usually fix the problem. Otherwise replace the supply.
Jun 07, 2009 | LG 20LS7DC 20 in. LCD TV
NO PICTURE LG 20LS7D LCD Flat panel TV
Worth repairing, you need to replace the Y drive and Y sustain modules, parts about $300.
Jun 29, 2008 | Televison & Video
LG 20LS7D TV
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key.
then the fly back unit is failed you need to resolder the contacts or get it serviced...............
Jun 08, 2008 | LG RE-20LA70 20 in. Analog TV LCD...
LG 20LS7D
It uses a regular power cord, the kind that you would use for a PC.
Dec 07, 2007 | Olevia LT23HVX 23 in. LCD Television
Televison & Video Logo
209 people viewed this question
Top Televison & Video Experts
