Its not detecting the new cartriges for some reason.. Silly Question?? Did you pull off the blue tape tab off the new cartrige before installing them?? Oh ok If you did then you might wanna very carefully with the unit unpluged is to clean the copper colored contacts on the printer itself with a small amount of alcohol and let dry completely before you use it and see if that helps and if it dosent Im sorry to say its not worth taking in to be servived as a compadable puter printer can be bought here for under 50 bucks.. Good Luck
Just because the ink jets are new doesn't mean they are full from the factor or from the remanufacturer. This is often the case we get the generic and get burned because we think we get a better deal when in reality we only get burned.
I have canceled all print jobs and shut down the printer and computer and re-started but the problem...
(More)
I have canceled all print jobs and shut down the printer and computer and re-started but the problem persists. This is a "new to me printer" and I successfully downloaded the software from an HP site and it is showing the printer. What is wrong? I tried printing from Notepad- following the instructions and that didn't work either. Any ideas?
i have recently changed isp from aol to talk talk, ow using outlook express and internet explorer,...
(More)
i have recently changed isp from aol to talk talk, ow using outlook express and internet explorer, my printer will now not print the same as whats on screen, and i now get all spurious garbled numeric text of which is unreadable, i have re-installed my printer twice but the problem persists can you help please??
Unit will not shut off - power button light stays on. parer feed button light is flashing. Printer...
(More)
Unit will not shut off - power button light stays on. parer feed button light is flashing. Printer will not print or feed paper?
Printer does not print test page or print documents from word. Printer does print alignment test...
(More)
Printer does not print test page or print documents from word. Printer does print alignment test page and ink flows from clean nozzle command. How do I fix the problem?
