Question about Acer Aspire 3000 Notebook
Acer Aspire 3000 problem
SiS UNDI, PXE-2.1
Copyright (C) 2003-2006 SiS Corporation
Sis900 PXE BootROM v1.09 - ZL5_0324 Use BEV/BBS
Client MAC ADDR: 00 C0 .... Guid: E0FADEF0-......
PXE-E51: No DHCP or proxyDHCP offers were received.
PXE-M0F: Exiting SiS PXE ROM.
Operating System not found
This happened after I upgraded to Vista home premium from XP Pro. Saw a couple blue screens and now when I turn it on I see the above message. Does anyone know what has happened? Do I need a new hard drive?
  • skidoo2 Sep 30, 2008
    sis900 pxe boot rom v1.09f - test use bev/bbs
    rest is same try to load os comes back with error
    Problem Solver:
  • 8 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} No. JUST RESET YOUR BIOS SETTING TO DEFAULT. Your HD is OK
Posted on Sep 30, 2008
  • kukidog Sep 30, 2008
    No. JUST
    Your HD is OK
The sound icon has disappeared from the task bar. I've checked control panel (sounds and audio devices) and the 'place volume icon on task bar' has gone grey and can't be ticked (it was ticked before icon...
hello from a few days ago I was working on my laptop and suddenly reboot. but now get a message that is:
sis UNDI, PXE-2.1
copyright PXE BootROM v1.09f - ZL5_0324 Use BEV/BBS
=== Press <Esc> to bypass LAN check. ====
him and tried to boot from the CD drive. order to retrieve information or other cases formatting. but when the process goes to the information is not in the hard disk.
Aug 17, 2013 | Dell Inspiron 1501 Laptop
Intel UNDI, PXE-2.0 (build 082) Copyright (C) 1997-2000 Intel Corporation
As soon as you power on your PC, start pressing the F2 key. This should bring up the BIOS (Basic Input Output Systems) screen. Make sure your Hard Drive is listed in the Boot order. Usually a CD drive is listed first, then the Hard Drive as a second boot device. If you do not see the Hard Drive listed, then it probably is bad and needs replacing. If it is listed correctly in the boot order, your Operating System has crashed, and you will need the recovery disks or the instalation disk for your Operating System (XP, Win7,etc.)
Aug 11, 2012 | Acer Computers & Internet
Broadcom UNDI PXE-2.1 v12.20 copyright(c) 200 - 2009 broadcom corporation copyright(c) 1997- 2000 intel corporation all rights reserved client MAC ADDR: 88 AE 1D 6F 5A 3A GUID: 478ADE06 B852 67B5 10E7...
From the description it is the hard drive, remove hardware and reseat back into position, sometimes this will restart the hard drive, if no change chances are you will need it replaced, but I would suggest getting it tested first.
May 26, 2012 | Acer Aspire Computers & Internet
Sis900 pxe bootrom v1.09f
check the hdd cables and if it still does not register,try replacing it with a new one.good luck
Mar 18, 2012 | Acer Computers & Internet
Hi i just switch my laptop aspire 6920 on and its start beeping and then its show me Intel UNDI, PXE-2.1 (build 082) Copyright (C) 1997-2000 Intel Corporation For Atheros AR8121/AR8113 PCIE Ethernet...
enter to bios setup and remove Ethernet controller from boot sequence or make it last on the list. and about operating system not found if you already use your system without problem then reinstall the system from a cd .
Jul 23, 2011 | Acer Aspire 6920 Notebook PC
I have Dell Studio 1555, Vista but later intalled XP on drive D, I have problem my CD/DVD drive does not read the Data, CD does not revolve in high speed make the tak tak sound as it try to read bit after...
Your message indicates that Pxe Boot is enabled (boot from lan card), go to bios settings and from the list of first boot options, please select the hard disk (hdd) or Cd-rom as the first boot device, reboot your system and check whether this helps or not.
It is also necessary to disconnect and reconnect your dvd/cd rom's power cable and data cable.
If you don't know how to do, then just reset the bios settings to "load default" ...
Good luck.
Thanks for using FixYa.
Jun 24, 2010 | Computers & Internet
Lap top will go any futher than entry screen...
This is a normal set of messages for a computer that is configured to attempt to boot off of a network server. Most home computers and laptops don't normally do this. If you never saw this before, booting from the network is probably the last try the computer makes before giving up. Basicially it is telling you that there is no valid boot device to start the computer from. It used to use your hard drive, but now it cannot because it has been disabled in the BIOS or the hard drive has died. You can check this by hitting the key to enter the BIOS Setup program (generally F10 or Del, it tells you when it is booting up) and making sure that the system does see your hard drive properly in the BIOS and ensuring that it is either first or second in the boot order.
Apr 07, 2009 | Packard Bell Computers & Internet
Having trouble with boot up
It was unfortunate that the chat got disconnected deu to some unknown reason. I was able to find some solutions for you, however, to follow all those steps I would need to talk to you continuously. Whenever you see me online, please initiate a chat with me and we will carry on from there. good luck
Mar 26, 2007 | Acer Aspire 3000 Notebook
Aspire 3000 will not boot
Hello Halfwit, Your laptop is trying to boot from lan because it can't for some reasons to boot normally from the hard-disk. Try to listen if when you power on the laptop the hard-disk spins or makes any noises. If not there could be a problem with the connector that links it to the mainboard. If you hear a noise or the hard-disk spins then you may have a corrupted OS (windows) or some bad sectors problems. The best way to find out would be to try to boot the laptop by using a windows instalation cd. Boot from the cd-rom and check to see if the windows installer find your hard-disk and can copy files to it. You will need to change the boot order from bios to enable the cd-rom to boot first or enter some boot menu (if provided) and select " boot from cd-rom " or such thing. If you need more help with these please post back or contact me or other experts on the live chat function on this site. Good luck.
Mar 23, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
794 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
