My wireless router does not seem to be working? power is good, but when i plug in my computer and ps3 there is no connection.
  • ralphamale Sep 11, 2008
    my friend just came by and sorted it out for me.
    But thanks for the very prompt response!
  • 34 Answers
First thing I would like is the model of router you have. This is usually printed directly on the router itself. The second is to plug the ethernet cable (Looks like a big phone jack) into the computer and the Internet (Could be labeled WAN as well) port on the router. Then go to your computer click Start>Run then type cmd and press enter. You should have a black box appear, type ipconfig and press enter. Post back the result.
Posted on Sep 11, 2008
  • Arthur Keech Sep 11, 2008
    Not a problem, just remember we're here to help :).
I have to work from home, but my internet connection is not working anymore. Just wondering what could be causing this to happen and what are the solutions?
depends are you wireless or wired?if wired chech your router make sure the connection is good,bypass if necessary plug directly to the computer if that works you are ok you might have a bad router.If wireless you might want to do the same thing if that works you may have to reset the wireless router and reconfigure(wireless routers are reset by a button on the backside between the ports).
Good luck
Aug 26, 2009 | HP Compaq SR5702F PC Desktop
Cannot connect ps3 to Gigaset SE587 router
Before you test you connection see what the percentage of the connection is, if it's less then %50 it won't work with wireless unless you move it into a place with a better connection
Jul 15, 2009 | Sony Computers & Internet
Router wont let ps3 have ip adress
you need to open a incoming port for the ps3 on your router all you have to do is use the computer to go to your router settings then use whatever ip the ps3 is using and open a port for that ip address that should work but i dont have a ps3 so i dont know you could try that
May 09, 2009 | Computers & Internet
I CAN NOT CONNECT TO THE INTERNET ..using Linksy wireless remote
the wireless card installed to your computer is working..as you said you can view all wireless networks...your computer is good too...the only issue is you cant connect to the wireless router...
turn off and unplug the power cable of the Modem
turn off and unplug the power cable the router
wait for 30 seconds
plug in and turn on the modem, wait for all the light turn to solid green ( no blinking lights )
then power on the router
if you saw the wireless icon light turn solid...
go to your computer...right click the wireless icon...select repair
if this doesnt work....reset your internet router by press and hold the reset button behind the router near the power plug (atleast 15 sec)
then connect your PC..the wireless network dont have the WEP key anymore because of the reset..you can reconfigure and put back the WEP key when you get connected.
Mar 16, 2009 | E-Machines (T2958) PC Desktop
When i first connect my daughters computer with an belkin wireless router than i stop working than i purchase an d-link not thinking it would make a different but it didn't and still not working do i ahve...
No you can't use two routers (without being an expert to set them up correctly!). Make sure the Belkin isn't plugged in while you're setting up the D-Link. To diagnose the culprit, try these steps:
1) Plug your daughter's computer directly into the ethernet port of the DSL or Cable Modem. You'll need to do this to rule out your Daughter's PC as the problem. If it works fine, then move to step 2. If her computer still isn't working, and another computer connected the same way DOES work - then you need to work on your daughter's computer, becasue that's where the problem lies.
2) Ok since you confirmed your daughter's PC is just fine - and also the DSL or Cable connection is working as well - this indicates most likely the router(s) are at fault. So let's work with the D-Link, since we're not sure if the Belkin is working. Like I said, be sure the Belkin is completely unplugged and powered OFF. Now plug the D-Link into your DSL or Cable modem ethernet port. Turn on the D-Link, make sure the correct indicators are lit on both the DSL/Cable modem and the router. Reboot your daughter's PC and right-click on the wireless networking icon on her taskbar. Choose view available wireless networks - if you see your D-link listed, then the router is working! If you still can't connect - try disabling WEP/WAP and try again. Most likely it's just a security setting that's off.
Good Luck!
Dec 31, 2008 | Computers & Internet
Netcomm NP745n wireless USB adaptor drops in and out of connection on about a 10-15 sec, cycle
I would like you to attempt this troubleshooting technique which helps alot of people:
1st: Unplug your High Speed router then unplug your Wireless Router (ALL WIRES)
2nd: Shut Down your Computer(s)
3rd: After 60 seconds of your High Speed Router and Wireless router being disconnected please plug the High Speed router back in make sure that it appears Online/Connected then plug in your Wireless Router make sure that it appears Online/Connected.
4th: Turn on your computer, login in and reattempt connection.
If this process does not work, I would like you to take a few minutes and go over this URL that will help you find a place to put your Wireless Router to make sure you receive Good/Excellent Signal which is http://www.microsoft.com/athome/moredone/wirelesstips.mspx Microsoft "10 tips for improving your wireless connection." Is there anything else I can help you with?
Oct 27, 2008 | Computers & Internet
Hi...unable to connect to ps3 using siemans gigaset se587 wireless router
hi there,
first you need to make sure u can access your wireless router with no problems and the wireless is turned on for your ps-3...then u need to forward some ports...
Turn on PS3 and goto Settings, Network Settings.
Select Internet Connections. If it asks you want to be disconnected select Yes. Select EASY. Select wireless
Select SCAN this will take a few minutes. The PS3 should find your router and already have the SSID# so just type in your WEP key. Select save and then wait a couple of minutes then select test. It should hook up.
If it hooks up with NAT3 then you will have to enable UPnP on you router. type in http://192.168.1.1 on your computers web browser.
username: admin
password: admin
Click on the advanced tab and then on Universal plug n play and then make sure both check boxes are marked.
Then on the PS3 make sure the UPnP is enabled also in the network settings.
This should give you network and NAT2.
please try this link for port forwarding help:-
http://www.portforward.com/english/routers/port_forwarding/Siemens/GigasetSE587/PS3_NAT_Type_3_to_2.htm
Apr 20, 2008 | Computers & Internet
Hi my router wont connect to comp.need help making connection between router and computer
Here's How:
  1. Choose a convenient location to begin installing your router such as an open floor space or table. This does not need to be the permanent location of the device. Particularly for wireless routers, you may find it necessary to re-position the unit after installing it as the cables / signals may not reach all areas needed. At the beginning, its better to choose a location where it's easiest to work with the router and worry about final placement later.
  2. Plug in the router's electrical power source, then turn on the router by pushing the power button.
  3. (Optional) Connect your Internet modem to the router. Most network modems connect via an Ethernet cable but USB connections are becoming increasingly common. The cable plugs into the router jack named "WAN" or "uplink" or "Internet." After connecting the cable, be sure to power cycle (turn off and turn back on) the modem to ensure the router recognizes it.
  4. Connect one computer to the router. Even if the router is a wireless model, connect this first computer to the router via a network cable. Using a cable during router installation ensures the maximum reliability of the equipment. Once a wireless router installation is complete, the computer can be changed over to a wireless connection if desired.
  5. Open the router's administration tool. From the computer connected to the router, first open your Web browser. Then enter the router's address for network administration in the Web address field and hit return to reach the router's home page.
    Many routers are reached by either the Web address "http://192.168.1.1" or "http://192.168.0.1" Consult your router's documentation to determine the exact address for your model. Note that you do not need a working Internet connection for this step.
  6. Log in to the router. The router's home page will ask you for a username and password. Both are provided in the router's documentation. You should change the router's password for security reasons, but do this after the installation is complete to avoid unnecessary complications during the basic setup.
  7. If you want your router to connect to the Internet, you must enter Internet connection information into that section of the router's configuration (exact location varies). If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address by your provider (you would need to have requested it), the static IP fields (including network mask and gateway) given to you by the provider must also must be set in the router.
  8. If you were using a primary computer or an older network router to connect to the Internet, your provider may require you to update the MAC address of the router with the MAC address of the device you were using previously. Read How to Change a MAC Address for a detailed description of this process.
  9. If this is a wireless router, change the network name (often called SSID). While the router comes to you with a network name set at the factory, you will never want to use this name on your network. Read How to Change the Router SSID for detailed instructions.
  10. Verify the network connection is working between your one computer and the router. To do this, you must confirmed that the computer has received IP address information from the router. See How to Find IP Addresses for a description of this process.
  11. (If applicable) Verify your one computer can connect to the Internet properly. Open your Web browser and visit a few Internet sites such as http://compnetworking.about.com/.
  12. Connect additional computers to the router as needed. If connecting wirelessly, ensure the network name (SSID) of each is computer matches that of the router.
  13. Finally, configure additional network security features as desired to guard your systems against Internet attackers. These WiFi Home Network Security Tips offer a good checklist to follow.
Tips:
  1. When connecting devices with network cables, be sure each end of the cable connects tightly. Loose cables are one of the most common sources of network setup problems.
What You Need:
  • A network router (wireless or wired)
  • Network adapters installed on all devices to be connected to the router
  • A working Internet modem (optional)
  • A Web browser installed at least one computer in the network
Please let me know if you need any further help and I would be glad to assist.
Thank you for using Fixya and Good Luck
Apr 19, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
24 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
