Question about Cameras
I have just bought a second hand metz 45-ct-4 which I am attaching to a canon 30d. it only sometimes turns on ( batterys need cleaning ?) and only sometimes synchs with the camera? ie nothing for five shots, then it will go for a couple and then not.. any ideas, cable seems in good nick?
  • 667 Answers
You've kind of answered your own questions. I would try a new cable and yes, clean the battery contacts.
Posted on Sep 11, 2008
Not sure what i need to use the mecablitz 60 ct-4 w/ my Nikon d-100
I just bought a D100 (as a backup to a D200 - nothing like being up to date with current technology! B^)). As I understand it, there is no integral flash sync connector on them. You need to get an AS-15 accessory shoe adaptor which goes on the hot shoe, and has a pc sync connector (like the D200 has on the side of the main body). Then you use a standard Metz sync cable to attach to that. The Metz 60 CT flashes have a low voltage trigger circuit and so should be safe with any camera.
Jul 10, 2011 | Metz Mecablitz 60CT4 TTL Flash
Where can I get battery power pack(shell with recharchable batteries inside) for metz 45 cl series,good second hand,off market brand,or even geniune brand,thank you
I have a lot of old 45-40 Series Metz 45 NiCd battery packs, that I will eventually rebuild with new NiCd batteries. I got them from Photographic Trader magazine and from ebay. I've heard that NiCd cells are going out of production, in favour of NiMH cells. I've found it's easier to put NiCd or NiMH cells in the alkaline battery holder, the flash recycle time is only slightly longer. I charge them separately out of the holder, or in the holder with a connector I made. NiMH cells need a suitable charger, with peak detection, as NiMH cells don't like being overcharged.
Nov 05, 2010 | Metz mecablitz 45 CL-4 TTL Flash
METZ 60 CT-4 batteries and capacitors
Although you can still get lead acid batteries from Sonnenschein (the original oem manufacturer) for the Metz CT60 units, a better choice are the Lithium ferrite phosphate or Lithium ion batteries, now available on ebay. For example sales8phd on ebay sells a drop in replacement 6 or 7Ah battery with a charger for ~$75. In general these batteries produce more flashes per charge than the lead acid oem batteries,particularly when shooting a lot of flashes in rapid sucession.
Jun 01, 2010 | Metz Mecablitz 60CT4 TTL Flash
METZ 45 CT 5 S O S
Check the polarity of the batteries.
With the batteries removed you will be able to see small
+ and - alongside each of the six connectors. Make sure the +
of the battery connects with the + connector. Similarly check the -
connections. With the batteries inserted (but without the plastic cap being fitted) you should see the ends of the batteries. Three positive ends (all in a row) and three negative ends.
If one, or more, has been inserted with the polarity reversed it will stop the flash from working.
It can also cause the handle to overheat.
May 02, 2009 | Metz mecablitz 45 CL-4 TTL Flash
AC Power Supply for Metz 45 ct5
Hi daf4,
I have a circuit diagram for the 45CT-5 and the flash unit as well. The voltage is 360V DC, which goes straight across the flash tube. The top pin is positive, when the notch in the socket is on the right hand side, i.e. towards the back of the flash.
I'm also looking for a circuit diagram for a 45CL-4, if you know anyone who has one.
Regards,
Neil
Feb 07, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Metz 45CL-4 Service Manual wanted..
Hi !
Here is a link to the Metz manufacturer:
http://www.metz.de/en/photo-electronics/instruction-manuals/mecablitz.html
I hope it will be to some help.
Regards Lars
Jan 27, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Metz 45 CT 1
I had that same problem also, but mines was temporarly. Ik think the condensor inside the Metz has to regeneratie (recover) itself by using with a full charged fresh batteries. The high freq. sound is normal. (although not to loud) after a 5 MINUTES the orange bulb should light up. How more u used how better the start-up time. My old Metz start-up time was around 40 sec. and now ot is within 7 sec.
Jun 22, 2008 | Metz 45 CL-1 Flash
Cannot fire off cameta
If the Metz 44 is older then 3 years, than it's an software problem. I Had the same with the Metz 44AF-C and my EOS 30D. The same metz works well with mij Rebel (300D)
Tweety
Jun 08, 2008 | Metz 44 AF-4 for Canon TTL Flash
Cameras Logo
76 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
