Question about Sony KV-27FS12 27" TV
PICTURE TROUBLE ON SONY TV ..KV-27FS12
THE PICTURE OF MY TELEVISION SONY HAVE A LITTLE PROBLEME....IT MAKE A BOWED PICTURE ON RIGHT SIDE AND IT HAVE THE PICTURE FLIPPING OVER ON THE LEFT NOT THE ENTIRE PICTURE BUT ON THE 1/4OF IT OTHER WISE EVERITHING IS OK GOOD RECEPTION OF CHANELS GOOD SOUND I REPLACE A CONDENSER C510 AND THAT IS WHERE I AM CAN YOU GIVE ME A HAND THANK YOU
    Novelist:
  • 130 Answers
Was the cap the right value? is it good? if you use a higher value what does it do?
Posted on Apr 13, 2006
    President:
  • 3,130 Answers
Why did you replace the cap?? was it bad?? what did you replace it with?? what was the problem before you replaced the cap??and when you say flipped over do you mean verticaly fliped ot horizontal??
Posted on Apr 12, 2006
  • 4 Answers
Most sony tubes bow in the corners, they just arent built that well
SOURCE:
I have a Sony kv-27fs12 the picture go out but you still can hear it and the standby light turns on first it flash 5 times then stop and do it again now flash continuously please if you know let me kn
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. If you want to know more about the blinking codes to Sony Brand TVs, check this link.
Jan 14, 2013 | Sony KV-27FS12 27" TV
When i try to turn on my sony kv-27fs12 keep turn off and blink 4 time a red led make a pause and keep blinking 4 times, what that could be?
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Vertical sweep failure. Check all the solder terminals to vertical output IC. If it do not help, replace that IC.
Jul 03, 2012 | Sony KV-27FS12 27" TV
Looking for a Manual
https://www.completeservicemanuals.com/sony/crt-television/kv-27fs12-service-manual/prod_225.html
has it for 8 dollars
Mar 13, 2009 | Televison & Video
No Power Sony KV-27FS12
IF the unit is completely dead (no standby light at all) then teh main fuse is most likely open. Try replacing that first. If the stnadby light is on, then when you attempt to turn it on, the light shouild blink. If so, the blinking should be a repeated count with a short pause between sequences. Post that count here as it will indicate what circuit has the problem. We will continue from there.
Thanks,
Dan
Feb 11, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Menu won't show.
sounds actually like it has had weather damage, sometimes water can get into a place it shouldnt on a tv, not shorting it out, but instead messing up in your case the numbers or menu screen, so i'd say it is best to take it to tyour nearest recycler, hope this helps.......jason
Dec 29, 2007 | Sony KV-27FS12 27" TV
KV-27FS12
hi there, there is a problem at your power supply section. do some test, it maybe a electronic part faillure. ty
Dec 28, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
PIP for Sony KV-27XBR45 television trouble shooting
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
Apr 13, 2007 | Sony KV-27XBR45 27" TV
MY TV SONY KV27FS12 PICTURE PROBLEME
Hey Rolly no problem man as if we can help ya your not taking up our time as we answer when we can. Ok theres is still a small cap somewhere by the drive ic or they call it the jungle ic. If you have a schematic scan the vert part and I will assist you the best i know how.
Apr 14, 2006 | Sony KV-27FS12 27" TV
Sony KV-27FS12 27" TV Logo
88 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
