Question about Miele Novotronic Premier 500 Front Load Washer
Door will not close
The door will not close and thus engage power to washing machine. This has happened before but has come good.
  • Anonymous Dec 15, 2008
    door will not close - how do I open the front panel
    New Friend:
  • 128 Answers
Believe it or not the door sometimes needs to be slammed - try it and see if it works - if not the lock needs to be aligned with the latch
Posted on Nov 30, 2008
I had no power 15 minutes after the installer left.  I went online and found the solution of slamming the door.  It worked!  As soon as the door was slammed shut, I could push the power button and all the lights came on.  Thanks!!!  Ready to wash clothes in Texas thanks to you, mpservices, who posted the solution Nov. 30, 2008 to my problem today.
Posted on May 23, 2009
What is this? I can't find it in the manual. I turn on the dishwasher and nothing happens.
I think your problem is with a bad contact switch. Most likely at the door. When door is closed this switch makes contact to engage machine to start. Your machine is electronic, some machines would need a lever to be moved to enable machine to be started. It all comes down to the same thing, power must flow to start the washing. You will need to look for this contact somewhere around the door. GOOD LUCK FRIEND.
Jan 18, 2015 | Fagor Commercial AD-48W Temperature...
Smelly washing machine
Hi Haydn.
One of the main reasons for smelly machines is because the door is left closed and mould is growing in the drum and door seal.
Using some chlorine bleach will help. Put some in the drum and do a 'Rinse & spin'.
Leaving the door slightly ajar will allow the drum to dry and it will also allow the rubber seal to relax, thus maintaining a good contact with the glass when in use.
Once it's established mould can be difficult to get rid of entirely.
Good luck.
Nomess
Jan 11, 2015 | Bosch Washing Machines
Have power but won't start
All automatic washers are programmed to "latch" the door closed before it will move the basket. Check to see that the latch is engaging the door.
Jan 14, 2014 | Samsung Washing Machines
My Hotpoint WF000 washes the cloths but won't spin. The On/Off light flahes but nothing else happens. Any advice???
Check the door is closing proerly and is fully engaged,.
Check door interlock, and the control module connections.
Hope this is of some help to you.
Dec 05, 2009 | Hotpoint Washing Machines
I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Apr 01, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
My clean light is flashing....call service to check heater?
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water. Check the element for damage (burnt/shorted).
To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 05, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Elite HE3 washer lights light but wash won't start
Sometimes I just have to unplug the machine, wait a few seconds and plug it back in and it works. I guess it resets itself or something.
Feb 26, 2009 | Kenmore Elite 45986 Front Load Washer
Front loader not starting
First check if u can close the door with no or less clothes and see if the lock is engaged.. else if u find the door not locking see if there is any garments or threads blocking it.
Thankyou
Jun 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Miele Novotronic Premier 500 Front Load Washer Logo
319 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
