-   within 1 year of having the electrolux built in oven eog9330, the door would not close flush, the heat came out of topv and because of pushing this, the glass flipped out and smashed. That cost £70 needed fitting and the door is still not flush.-   judithpratt0
Jan 13, 2009
-   the bottom oven doordoes not fit tight anymore. I keep it tight with a chair help !!!-   Guest
Nov 20, 2007
-   Over Door will not close fully-   Guest
fan does not work when i use oven or grill, the oven just heats up and then overhaets, do i need to...
(More)
fan does not work when i use oven or grill, the oven just heats up and then overhaets, do i need to replace fan or is there a more serious problem
when i use the oven or the grill; i put on the switch gas .the lightern begin to sparks and never...
(More)
when i use the oven or the grill; i put on the switch gas .the lightern begin to sparks and never stops even when the oven get on .
my electrolux double gas oven drips from the bottom on to housing door. I had repair men around who...
(More)
my electrolux double gas oven drips from the bottom on to housing door. I had repair men around who said seal is ok?? Any ideas please
eog9330xn Gas oven with grill decided not to come on .. ie no electricity > Any suggestions as I...
(More)
eog9330xn Gas oven with grill decided not to come on .. ie no electricity > Any suggestions as I cant see where the fuse may be
