Question about Brother IntelliFAX 770 Plain Paper Thermal Fax
Not receiving incoming Fax
I am able to print copy as well as send a FAX however the incoming FAX messages are not being received
    Master:
  • 726 Answers
Is the number for incoming fax correct and setup properley
Posted on Sep 11, 2008
2 Suggested Answers
MerlinTech
  • 197 Answers
SOURCE: fax problems
ok..let's start with this step
go here, get a fresh set of drivers, and remove old s/w, then install the new set
Posted on Jun 18, 2008
When receiving fax, it won't print
make sure the property settings for the fax are not on the Microsoft printer make sure it is set to the local usb printer
Jan 28, 2014 | Brother MFC-J625DW Wireless All-in-One...
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
Fax can do copies and send but not able to receive incoming faxes. Did several tests. Modem picks up but doesn't transmit data. LCD screen does not indicate any trouble or alarm.
It's possible that somehow the incoming faxes are going directly to memory and not printing. If there was a Tx issue, you'd get an error message on the LCD screen or a printed out message. Not knowing what kind of machine you have, I can't give you instructions to print from memory but if you check your manual, you should see instructions to both print from memory and set the fax to print automatically.
Nov 18, 2009 | Office Equipment & Supplies
Brother Intellifax-2820, will not print incoming faxes. It rings, says it's receiving data and thats it. Yes I have paper in tray. Sends and copies fine.
You need to make sure that your machine is set to "FAX" mode,not"PHONE"mode and that it is in "AUTO"receive, not "MANUAL"receive mode.
Oct 04, 2009 | Brother IntelliFax-2820 Laser Fax
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Fax not receiving
if there are "empty toner"
the printer not print received fax until cartridge replacement.
May 21, 2009 | Samsung SCX-4828FN All-In-One Laser...
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Brother IntelliFAX 770 Plain Paper Thermal Fax Logo
203 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
