Hi I have a JVC GR-AXM710 that plays back fine, but when put in record it shows a black screen through both the Vf and the flip-out screen. It records audio fine. I have seen many JVC and hitachi camcoders with this fault, it may be the CCD, but I suspect it is some of those wonderful smelly aluminum capacitors gone bad, as it was working perfectly when last used, but sat for a year or two, and those caps seem to go leaky if camera is used or not. Anyone with more camcoder experience who could maybe save me some time with specific caps to check, etc... I would appreciate it greatly.
P.S. I also have an even older GR-AX5BKU with exact same fault.
-   i have a panasonic sd that plays back fine but the screen is black. it shows the display and plays audio. when i play a tape it shows and when im looking at pictures it shows but when i record i get nothing but display and sound.-   lbenford
Feb 05, 2008
-   My Canon MV940 has the same problem with the flip screen - a sort of "now you see it, now you don't" drop out of the image between the flip screen and the viewfinder. Same as others, I discovered by chance that when the screen is reversed and even flipped back into the side of the camera it works again - but is no good there! Sometimes the viewfinder also goes back for a second then comes back. I want Canon to tell me why this is happening to a relatively new camera. Mike, Adelaide, Australia. -   Gem550
Jan 13, 2008
-   mine has this problem. but if I flip the lcd to where it's facing away from me it comes on. that's not going to be of any use unless I have the camera pointed at me and want to make sure it can see me. when I flip it to any other position the lcd screen turns completely off.-   Guest
Jan 11, 2008
-   I have the same problem with my sony hanycam dcr-dvd100 it plays previously redorded videos but otherwise the LCD screen is pitch black....it does record the audio however and plays it back but no luck with the visual.....does anybody have any suggestions?-   Eazy Ed
Jan 03, 2008
-   my jvc GR-D72 camcorder, plays back pretty well, and record audio but no picture when i tried to record through both the lcd and the viewfinder, everything on it's screen is just plain black, with the battery bar and the recording signs beeping, i will surely appreciate any help to restore my camcorder recording mode back.Thanks-   dareal09
Oh yes it could be the pan caps as we call them as where if left long enough will distroy the PCB!! Anther common trouble with these jvcs as well with some other brands of camcorders is a stuck iris assy as oil or dust gets on them and stops it from opening at power up But I suspect the cap problem and Im sorry to say is most likely cost prohibited because you may have to replace the entire PCB if its even still available.. Oh the uto iris i9s built deep inside the lens assy and the lens has to be taken off the camcoder body abd disassembled and take a bit of time to do. Good Luck
Apparently this same problem exists on many different models. I have a JVC grd72u. I called JVC @ 800-252-5722. I selected the "Corrective Action Program" prompt from the automated attendent. I spoke to a customer service rep. They are aware of the problem and are fixing it for free, but only until 12/31/07. I suggest you call ASAP and get your name in the computer. If the problem is something besides the CCD sensor, they will call you with the estimate to repair.
WIndows 7 does not recognise canon mv630. I want to capture my videos from my camera. I have winfast...
(More)
WIndows 7 does not recognise canon mv630. I want to capture my videos from my camera. I have winfast DTV and windows 7. I have installed the drivers for the camera but when I go to capture the video Nero tells me it can't initilaise the video capture device.
My Canonzr45 is working perfictly.All I want is for the videos to go on my PC and then to YouTube....
(More)
My Canonzr45 is working perfictly.All I want is for the videos to go on my PC and then to YouTube. PS.The camcorder has a tape to save its videos.
I have a JVC VHS-C gr-axm710u that takes digital still photos, I can't get the pictures to download...
(More)
I have a JVC VHS-C gr-axm710u that takes digital still photos, I can't get the pictures to download using their Picture Navigator, when I select Camera ready to download I get a connect error and that is all. I have the cable connected directly to on my Windows NT computer.
hi my camcoder head chip is broken. can i replace or get the item at guwahati,assam, india. faruk...
(More)
HI MY CAMCODER HEAD CHIP IS BROKEN. CAN I REPLACE OR GET THE ITEM AT GUWAHATI,ASSAM, INDIA. FARUK IQUBAL,INDIA farukjcfti2gmail.com
i can't seem to get the pictures i took off the camera onto my computer? connection error keeps...
(More)
i can't seem to get the pictures i took off the camera onto my computer? connection error keeps coming up? what could it be? thanks in advance for anyones help. koolaidking58@hotmail.com and say camcorder for subject or it goes out with the trash. lol
I have a sony dcr hc14e, it has a problem like this, just play back is good but will not record. The view finder and the screen both are black. So i need a help, thanks.
Comment by Guest, posted on Nov 25, 2007
My brother dropped my camcoder now you cant only see when your recording things
