Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Removal of cltuch from 1999 Harley Davidson Road King
I can not get the clutch off so I can remove the inter primary casing
  • 216 Answers
You know that the threads are reversed on the clutch hub nut ? you need to turn it clockwise to loosen.
Posted on Sep 11, 2008
How to change the oil on a 2004 flhrs primary trans. oil change
Drain from the drain plug on the bottom of the primary case and refill only up to the bottom of the clutch diaphragm spring through the clutch inspection (derby) cover.
Jun 03, 2014 | 2005 Harley Davidson FLHRS - FLHRSI Road...
How do i replace the clutch plates on my 2009 roadking?
Hi Duckie, for more information about your question please visit the websites below. Good luck and have nice day.
Harley clutch pack replacement on twin cam 2 7 remove outer primary
Aug 13, 2012 | 2009 Harley Davidson FLHRC Road King...
Replace drive belt 2003 harley road king
this is a pretty big job, the whole primary needs to come off, clutches, compensating sprocket, and inner primary. you need to unbolt the swingarm, remove the left side isolator, unbolt left shock, carefull sneak the belt between the trans housing and swingarm. If you wanna tackle this yourself. your are gonna need a manual, there are alot of specs to follow. you really need to look closely at the 3 transmission seals, any wetness, i would change them, i usually change them all anyway. you need to change the inner primary seal and starter shaft seal while you're in there.
Mar 20, 2012 | 2003 Harley Davidson FLHR Road king
Let out clutch oil by mistake how do i replace it an what kind and weight
Remove the derby cover from the primary cover. Pour one quart of H-D 20W50 Syn3 engine oil in the primary. It should fill the primary to the bottom of the clutch hub. Do not overfill.
Steve
Jul 21, 2011 | 2005 Harley Davidson FLHRS - FLHRSI Road...
Change a drive belt
to change the final drive belt on your Road King, you must pull the entire primary off. The outer primary cover, the clutch and primary chain, the inner primary, and the starter must come off. Then, you have to remove the rear wheel, remove the shocks, and pull the swing arm out as well. It's a major job.
Good Luck
Steve
Feb 19, 2011 | 2000 Harley Davidson FLHR-FLHRI Road king
How do I replace a drive belt on a 1999 harley
On a Big Twin, you must pull the entire primary drive off the engine.
Disconnect the battery. Take the outer primary cover off the engine. Remove the compensator (engine sprocket) nut. This nut is very tight and has Loctite thread locker on it. 150-165 foot pounds of torque. You'll need to something to lock the chain up so the engine does not turn while loosening or tightening this nut. We use what is called a "locking bar". Remove the small plate with the screw and locknut in the center of the clutch assembly. Remove the mainshaft nut up inside the clutch assembly. It torques to 60-80 foot pounds LEFT HANDED TREADS. Remove the nut from the primary chain tensioner. Grab the compensator sprocket and the clutch assembly and lift the primary drive out of the cover.
Take the small screw out of the center of the jackshaft and remove the starter jackshaft.
From the right side of the bike, remove whatever you have to remove to get to the starter, exhaust pipes or whatever. Disconnect the battery cable and the small wire from the starter. Remove the two bolts holding the starter on inner primary cover.
Go back to the left side of the bike. Remove the four bolts that holds the inner primary to the engine, and the two that hold the primary to the transmission. There's one bolt coming in from the backside that has a braided wire on it on the early models. There may be four bolts holding the inner primary onto the transmission. When you have all the bolts out, the primary will come off easily. If it does not seem to want to come off, you may still have a bolt somewhere. Do not beat on the primary cover with even a rubber hammer. It should come right off.
Now, you'll have to remove the rear wheel, rear shocks, belt guards, and remove the swing arm.
As you can see, it's a pretty involved job on a Big Twin.
Good luck
Steve
Jul 27, 2010 | 2000 Harley Davidson FLHRCI Road King...
Clutch chattering while releasing clutch on 2008 road king
This is indeed an unusual problem for such a late model bike. The old Shovelheads used to do this from time to time but Harley quit building them in 1984. I've never had an Evo or Twin Cam bike come in with this problem.
However, what we used to do with the Shovelhead clutches is to take the clutch apart, clean the disc off with gasoline, and lightly sand the disc. The disc would get a glaze on them and gasoline was the only thing that would take it off. You had to be very careful due to the volatility of the gasoline.
Doing this may or may not be within your capabilities to repair. It would require that you remove the outer primary cover and disassemble the clutch assembly. You could try that if you wish but like I said earlier, this is a problem that I've never run across since the introduction of the Evo engine and the clutch assembly they employed after that. Make sure you check the tension on the primary chain and the oil level in the primary case.
Good Luck
Steve
May 27, 2010 | 2008 Harley Davidson FLHR Road king
Replaceing drive belt 2001 road king
you will have to remove the compesator nut and the circlip in the centre of the clutch hub , remove the nut securing the clutch basket on (left hand threads on this nut so be carefull ) remove the little jackshaft nut and stater gear then remove the 2 bolts holding the starter motor on then you will find 6 or so bolts holding the inner primary case on remove these and the inner primary case will come free with a little jiggle. unfortuantaly you will also have to remove the rear wheel ,suspension and swing arm to get the new belt on. hope this helps
regards
bert31000
Mar 18, 2009 | 2001 Harley Davidson FLHR - FLHRCI Road...
Primary case
3/4 of a quart or bottle of primary chaincase fluid or change to 20/50 synthetic and dont worry about changing it for about 6000 miles the oil can be put in by removeing either cover hope this helps
Nov 10, 2008 | 2006 Harley Davidson FLHR Road king
Lands Phones Logo
180 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
