Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Memory (sim?) card
Where would I find a memory card in my krzr if it has one?
  • BrutherG Sep 24, 2008
    I can see my background,it says only emergency calls,and it says to INSERT SIM
    Problem Solver:
  • 6 Answers
Hi
Take off the cover as if to access the battery / sim card . The memory card is inserted into the silver clip bottom right as you look at the phone. It sits over the sim card and is a micro SD type card. My K1 has a diagram wiv an arrow pointing right on the bit you insert your sim card to.
Hope this helps
M00zy
Posted on Sep 26, 2008
  • jolu
    jolu Jan 13, 2014
    no tengo espacio y no agarrala memoria
Ubicacon de la memoria
Posted on Sep 16, 2008
4 Suggested Answers
SOURCE: Motorola KRZR K1freezes with SanDisk 2 GB Memory Card - Micro SD.
You have a option in the memory card settings to format. It will format, but still after loading some data into memory card the mobile starts freezing again, even im suffering with the same problem for a long time
Posted on Jan 31, 2008
SOURCE: memory card for motorola krzr k1
try formatting & inserting it again.......
it may solve ur prob
Posted on Feb 10, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: krzr k1m where does sim card go. instructions say
turn cell over face down...press the button at top (with your right thumb) of cell ,slide the back cover off with your left thumb...the battery is there take battery out slide the sim card in the slot the now...place battery back in (the gray metal clip over the sim card is a slot for a sdmirco card (more storage you might wanna invest in ($4 -$10)
Posted on Jun 17, 2010
I need a subsidy passwork for a Rogers Motorola krzr k1 IMEI 359206011317237
It is very simple to get Subsidy Code for Motorola KRZR K1 Phone....Visit the site
Theunlockarena.com get Subsidy Code and unlock it easily.
Motorola KRZR K1 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Motorola KRZR K1 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola KRZR K1 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola KRZR K1 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola KRZR K1 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola KRZR K1 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Nov 03, 2012 | Motorola Cell Phones
I have an old motorolo krzr k1 i have changed mobile phone company and want to use my old phone it asks me for operator code can you help
if you were tmobile (you had a sim card)..so if you switch to any other carrier that is using a sim card...you call that new phone company to activate both sim / cell.........
Mar 21, 2010 | Motorola Mobility KRZR K1 Cellular Phone
Krzr k1m where does sim card go. instructions say under memory card but theres nowhere to insert card
Mar 07, 2010 | Motorola Mobility KRZR K1m Cellular Phone
Motorola krzr k1m + 2gb memory - won't read the card
for your added information, it is by chance that the 2 gb sd card can be recognize by your phone. normally, krzr 1 doesn't support 2 gb. you may think that others do have. it all depends on the firmware they have and sometimes on the brand of the sd card like micromax
it is really by chance that it will be recognize. most of the time, it can be hardly recognize.
take care.
Feb 07, 2010 | Motorola Mobility KRZR K1m Cellular Phone
Unreadable memory card!!!!motorola krzr k1
you may have to buy a memory card reader, plug it into your computer and format the memory card before it will work in your phone, or your phone may require a different format of the same card, for instance some camera's take SD cards, and some take the HD/SD card, and they are not interchangeable, the SD will not work in the HD/SD device and vice versa..........hope this helps........
Aug 22, 2009 | Motorola Mobility Car Charger For KRZR...
Memory card placement??
the memory chip sits right on top the label should face up.
May 13, 2009 | Motorola Mobility KRZR K1m Cellular Phone
How do i get the sim card out of my krzr
turn the phone off..turn phone over take your thumb press down on top center metal part (while pressing down slide metal back away from phone......take the battery out.....slide sim card upwards...note...while open you will see a slot for a sd micro memory card also (directly under the battery)
Feb 24, 2009 | Motorola Mobility RAZR V3
Dec 25, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Memory card
try a master reset or clear (master clear may remove mp3s and photos)
Nov 26, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Save my address book from old sim card to new phone.
There should be a menu that when you put in a simcard, go to your address book and you can select each contact off the card, then select copy to phone. when you put back in your new sim card you have the option to transfer your contacts to the sim card, although you will then have duplicate copies of contacts and you will need to delete the contacts off the phone if you wish to keep them on the sim card only.
Sep 10, 2007 | Motorola Mobility MoroKRZR K1m Cellular...
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
115 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
