Two days ago I turned my computer on and where my sidebar gadgets should be there were black squares and rectangles. My clock was square with a black face and not working. I tried installing different gadgets with the same results. I bought this computer on 7/31/08
  • Don Perdew Sep 11, 2008
    Thank you very much. I have my slideshow, clock, and weather. My calender comes up closed.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 130 Answers
Hello Donpd,
I have the solution to resolve the issue.
Perform the steps as provided below:
1. Close windows Sidebar. Right click on the Windows Sidebar notification area icon and click Exit.
2. Open the Start menu and click All Programs, then click Accessories. Right click on Command Prompt and click Run as administrator.
3. In the command prompt, type "regsvr32 msxml3.dll" without quotes and press Enter. Then click Ok.
4. In the command prompt, type "regsvr32 scrrun.dll" without quotes and press Enter. Then click Ok.
5. In the command prompt, type "regsvr32 jscript.dll" without quotes and press Enter. Then click Ok.
6. Turn Windows Sidebar back on.Check to see if Windows Sidebar is displaying correctly now.
Posted on Sep 11, 2008
How many squares in a rectangle has a perimeter of 40
That depends on the rectangle.
A 1x19 rectangle has 19 squares.
A 2x18 rectangle has 36 squares.
A 9x11 rectangle has 99 squares.
A 10x10 rectangle (a square) has 100 squares.
All of these rectangles have a perimeter of 40.
May 29, 2014 | Computers & Internet
What is the greatest perimeter that a 48 meter squared rectangle could have?
Infinite.
A one meter by 48 meter rectangle has an area of 48 square meters and a perimeter of 98 meters. A one centimeter by 4800 meter rectangle has the same area and a perimeter of 9600.02 meters. A one millimeter by 48,000 meter rectangle has the same area and a perimeter of 96,000.002 meters. A rectangle one micron by 48,000,000 meters has an area of 48 square meters and a perimeter of 96,000,000.000002 meters. Keep making the rectangle skinnier and skinnier without changing the area, and the perimeter keeps getting longer and longer.
May 01, 2014 | Computers & Internet
How do i remove the sidebar
vista
On the Windows desktop, mouse over the sidebar and right-click on the search gadget you want to remove.
Click on "Close Gadget." The search function is now gone from the sidebar; however, the search gadget is still installed on your computer for future use if you ever decide to re-add the item to your sidebar.
To completely remove the sidebar search gadget from your entire computer, follow the next steps.
Right-click on the Windows sidebar.
Click on "Add Gadgets" to open a window containing all sidebar gadgets installed on your PC, including the search gadget.
Right-click on the sidebar search gadget you want to remove, and click to select "Uninstall."
Click "Uninstall" again when a Windows notification pops up, asking you to confirm the uninstall process.
After you click, the program will automatically be removed from your PC and it will no longer appear on the listing of available sidebar gadgets for Vista
windows 7
Click "Start."
Click "Control Panel."
Double-click "Windows Sidebar."
Remove the check from the box next to "Start Sidebar when Windows Starts."
Click "Save." Now, the next time you load your computer Windows Sidebar will not start.
hope this helps
Aug 24, 2012 | Sylvania G-Netbook
Wooden piece puzzle square/rectangles various sizes coloured dots
it's okay I ended up finding the instructions. thanks.
Dec 23, 2009 | Puzzle Toys
Is a rectangle squared or cubed
Some wires got crossed here. A cube is a solid (a 3D object), whereas a rectangle and a square are 2D figures. You cannot compare a 2D figure with a 3D figure any more than you can compare say a parking lot and a highrise building.
A rectangle is a quadrilateral (closed polygon with 4 sides). In a rectangle, opposite sides are parallel and equal in length. In a rectangle all 4 angles are equal, each measuring 90 degrees.
All this is true for a square, except that all sides are now equal. So you can say that a square is a special kind of rectangle, namely, a rectangle with equal sides.
Hope it helps.
Oct 08, 2009 | The Learning Company Achieve! Math &...
Mitsubishi 1995 cs31205 32 inch tv
Good Day;
Sounds like you have the TV in the "close caption " mode (text), turn off. 2. Check batteries and the mode the remote is in; eg TV, VCR, Cable & ect. Good Luck, big IRISH.
Oct 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Black square on tv screen
Turn off your closed caption...
Bill
Mar 20, 2008 | Televison & Video
Black squares or rectangles over picture
It's the closed captioning. The reason it doesn't go away when you press the "caption" button is because there are four option for closed captioning: Text 1, Text 2, Text 3, and Text 4. The fifth option, which has no designation, is the "off" option. Using the remote, just click on the "caption button until the option has no designation.
Mine was a large black rectangle in the middle of the picture. It's not like Nina3's problem.
Feb 01, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Windows Vista Sidebar Gadgets Not Loading Properly
1.) close sidebar and exit it
2.) accessories> command prompt [right click and choose 'run as administrator']
3.) type in these three in the given order
regsvr32 msxml3.dll [enter]
regsvr32 scrrun.dll [enter]
regsvr32 jscript.dll [enter]
after each enter you will get a success dialog window
Open sidebar and it should work.....
Jan 27, 2008 | Microsoft Windows Vista Ultimate Edition
62' Mitsubishi WD-62525 little black and white squares instead of picture but I have sound
Mitsubishi list this problem and has a solution of replacing several small surface mounted caps and diodes. we have tried this repair 5 times and only successfully done it once. so replacing what is called the formatter board part # 930B924002 for around $ 350.00 usually repairs this type of failure, However changing this board is a time consuming thing and takes a lot of Patience. It is buried deep in the set and several other board have to be removed just to get to it
Oct 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
