Olympus m:robe MR-500i  MP3 Player
Problem for Olympus m:robe MR-500i (20 GB) MP3 Player
When i turn on my mp3 it says system failed what does that mean and how do i get it fixed
By mzmndal on Apr 11, 2006
when i turn it on it blinks nd says system failed i think something is very wrong can someone please help me and how do i get this fixed and will all my nformation be lost
Same Problem
Jun 17, 2008
-   Mine says load main image failed switch to recovery mode. how do i do this?-   Guest
May 06, 2008
-   when i turned it on it said fatal error service required /004 what do i do?-   jami619
Best Solution
posted on Apr 11, 2006
Helpful)
techman
Rank: Guru
Rating: 86%, 7629 votes
Its a good possibility that the hard drive could be damaged from a drop or sharp inpact of some sort. Now if you say you didnt drop it then the hard drive probly needs to be formatted and yes you will lose all your programming. Send the unit to the manufacturer to get an estamate or take to an authorized repair center.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jan 25, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
check if the hold is on. if it is, then it won't turn on, and says that.
Solution #3
posted on Jan 22, 2008
Not Rated)
danjtaylor
Rank: Apprentice
Rating: 0%, 0 votes
The same thing happened to me. One of the solutions was that if you took the mp-3 remote and while holding the on button;on the remote you would also push the little heart; the mode and the play buttons all at the same time. Well when I tried this it did not work and nothing changed. The other solution which worked very well was to take the back off via the 4(four) little screws and there is 3(three) wires coming from the battery and going to a plug....... Unplug it wait at a minute at least. That should and will reset the camera's disc drive. Because of this fairly easy task (other than the tiny screws that jump all over the place) my camera is back in action and like brand new.....fantastic!!!!!!!!GOOD LUCK AND HAPPY PIX...................................................
Was this helpful?
Yes
No
Solution #4
posted on Nov 08, 2007
Not Rated)
MrJodie
Rank: Wiz
Rating: 83%, 89 votes
Apple has reported that they have had several bad "batches" of hard drives. Your best bet is to make an appointment at your local "Genius Bar" (the Apple Store Tech Support counter) to have it checked. They will be able to connect it to a diagnostics unit that identifies the serial number on the drive and determine if it's listed in one of the batches. They will also be able to tell you if the unit can be reinitialized. However, the bad news is that in just about every scenario you'll lose the data on the device. That's one of the reasons it's so important to keep it syncronized with the iTunes on your computer!
Was this helpful?
Yes
No
Solution #5
posted on Aug 11, 2007
Not Rated)
lokturna
Rank: Apprentice
Rating: 0%, 0 votes
download more song the other ones will get erased though but it will work!
Was this helpful?
Yes
No
Solution #6
posted on Jul 29, 2007
Not Rated)
frit
Rank: Wiz
Rating: 84%, 180 votes
Do you have the remote for this unit and if so have you attempted to do a reset?
Was this helpful?
Yes
No
Popular Solutions for Olympus m:robe MR-500i MP3
Questions and Unsolved Problems for Olympus m:robe MR-500i MP3
Do you recommend Olympus m:robe MR-500i (20 GB) MP3 Player?
Answer
Answer
I turn the device on, after a few seconds, the screen will display a message "Please reconnect... (More)
Answer
hello, mi mrobe 500 explain this message and not play, ERROR DE BASE DE DATOS, VUELVA A CONECTAR AL... (More)
Answer
When I turn it on it says system error and has an error code and it just stays there what can I do... (More)
Answer
how can i install the music/photo organization software m:trip because i lost my cd-rom
Answer
i have a m:robe i charge my m:robe but when i take out the m"robe it turn off
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Olympus m:robe MR-500i MP3...:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 756
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
