Question about Breville ESP8XL Espresso Machine
I purchased a new machine and cannot seem to get the stainless steel filter to fit into the filter holder and then fit into the slots - what is the trick?
    Problem Solver:
  • 18 Answers
Try this: on the handle there is a black clip that needs to be slid back away from the filter holder; filter basket should now fit (more or less); the markings for lining up the filter-handle into the brew-head slots are a little off; look up at the brew head, familiarize yourself with the location of the slots; line up the filter handle (make sure that black tap is still pulled back, or it won't go in). hope this helps!
Posted on Jan 11, 2009
Hi,I just bought a Aroma Saeco Manual Expresso machine from Amazon.
make your concerns known directly to amazon and if they will not assist then return it for a refund as it is not fit for the purpose
Feb 07, 2016 | Saeco Aroma - Stainless-Steel
Plugs in but wont turn on
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric ...
www.amazon.com/Koldfront-Bottle-Stainless-Slim-Fit...
Amazon.com, Inc.
Rating: 3.7 - ‎42 reviews
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric Wine Cooler - Black/Stainless Steel ... Item model number, TWR121SS .... the fridge. so you hvae to take out a wine bottle to reach it an usually I would like the controls on the door and only turn in .... The door can be reversed which the description did not mention.
www.edgestar.com/Koldfront-12-Bottle-Stainless-Steel-Slim-Fit-Thermo...
Koldfront 12 Bottle Stainless Steel Slim-Fit Wine Cooler Primary Image ... steel, the Koldfront 12 Bottle Slim-Fit Thermoelectric Wine Cooler (TWR121SS) is ... cabinet and stainless steel accents ensure that this freestanding unit will look ... Power: 70 W/0.95 A .... Unfortunately, your browser does not support video elements.
www.walmart.com/.../Koldfront-12-Bottle-Stainless-Steel-Slim-F...
Walmart
$109.99 - ‎In stock
Jan 20, 2016 | Koldfront 12 Bottle Stainless Steel...
How to remove the dispenser panel? PLHS269ZDBB
Check and ensure that the rod that hold these flapper is fitted properly in its slots.
Aug 03, 2014 | Frigidaire Professional Series PHS68EJSB...
Have a hotpoint washing machine wma34p. Brushes gone; got new one from the web genuine hotpoint part but comes in a ceramic holder ; does not fit; does not fit if take out of holder (one attached to motor)...
There was more than 1 type of motor fitted to this model of washer. so it is important to get the correct thype of brush.
Have you tried Hotpoint direct?
Go to---
WWW.HOTPOITSERVICE.CO.UK
Follow the menu on the left.
Feb 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Can not get fuel filter loose
The lines and fitting are so rusted it is advisable to replace the lines and fitting completely. The fittings are made of steel and the filter is all stainless steel. Tubing wrenches are best to use to try and remove these fittings. If not possible replace the fuel lines with compression fittings at the cut ends with the appropriate fittings at each end to fit the filter
May 23, 2010 | 2000 GMC New Sierra 1500
Want to replace dishwasher panel with stainless steel
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at applianceart.com. They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out www.applianceart.com
Jan 19, 2009 | Kenmore 13593 Stainless Steel Built-in...
Breville Die Cast 800ESXL
BrevilleUSA.com has a silicon seal (steam ring) to replace faulty or worn ones. There is no shipping charge, and they are $4 each. To replace the steam ring you'll need to remove the stainless spray disk on the brew head with a phillips screwdriver (one screw) and pull off the old ring (pay attention to the direction and placement of the stainless disk).  Takes about 2 minutes to do.
Part # .800ESXL/192
Also, on mine I noticed that the filter holder was ground down at the factory a bit too much on one side, which causes a slight leak down one side (coffee, not water).  You might check the holder (with the filter removed) for imperfections that could lead to your leak. Good luck.
Feb 17, 2008 | Breville Die Cast 800ESXL Espresso Machine
Espresso
the filter has a little indent that must be placed correctly, if you put the filter in the holder and then rotate the filter you will feel it click into place when it is in the right position ( there is a gap for the indent at the front of the holder)
Oct 30, 2007 | DeLonghi BAR 140 Espresso Machine
Breville ESP8XL Espresso Machine Logo
116 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
