Question about Kenmore Washing Machines
No hot wated going into machine have cold water
    Genius:
  • 1,028 Answers
Possible screen plugged in inlet valve sand/rust/crud.. if screen clear and good supply water to valve suspect bad valve slim chance temp control
Posted on Sep 11, 2008
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
Hot water when cold is selected
""Selectedd cold / cold and machine fills with hot water.""
Is your machine a FAV6800A or FAV9800A? If it's one of those I Have specific info to troubleshoot in Service Mode.
We will go into Service mode and turn on the Hot and Cold water inlet valves from the console and make sure the correct water inlet valve opens and fills the machine...........Rich
and a p/n if you need to replace the water inlet valve assembly.
Apr 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Possible Mixing valve Problem
I would pull the lines off the back and check the inlet filter on the hot and cold sides of the water inlet and clean the screen style filter. If you just use cold is the water cold if the cold water valve was bad then you would get no cold wate when set to cold.
Jan 20, 2010 | Maytag PAV2300 Top Load Washer
The wm does not accept cold water. I put it on cold cycle and it does not work the water line is fine... what could be the problem ?
Why has nobody mentioned the fact that if you “draw off” hot water using a tap beside the washing machine you can get “instant” hot water to your hot-fill. I have been doing this for years – now that all my hot water is heated by a crabon-neutral energy source (either wood or solar) I feel it is even more energy efficient.
As for water consumption, my house has a secondary return pipe on the hot water circuit with a temperature sensor fitted to the pump so that it only switches on when you turn a hot water tap on – you than turn the tap off, wait 5-10 minutes while the water circulates, then turn it on again, by which time the hot water only has ashort distance to travel and you don’t waster much down the drain.
However, I have been interested to read about the pros of cold fill only, especially the arguments about such a small volume of water being used anyway and the possibly improved wash performance? Also, I was dismayed to read that washing machines with hot and cold fill don’t use the hot wate very efficiently.
So would I be better off going for a hot and cold machine while they’re still available or going for a high-efficiency cold fill only machine? I am still minded to get an LG with hot and cold fill… comments please?
Dec 04, 2009 | Washing Machines
Cold water fill
You need to open the back and follow the cold water hose to the solenoid. Tap the solenoid a few times wile you are trying to use cold wated. If not check for power at the 2 wires that go to this solenoid, if you gout power then you need to replace your cold water solenoid. I hope this helps. Don't forget to rate my answer, thanks.
Feb 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore Elite 42922 HE 3t
sojds as if theresnot addeguate wate rsupply going to unit make sure
both hot and cold water is supplied and working to the unit
Apr 02, 2008 | Kenmore 46462 Front Load Washer
No hot water to wash
Is the hot water hot that is coming to the washer? Are you using the correct settings on the unit? If yes to both then either the solinoid water valve is bad or the timer switch unit is bad. Try going to a totally hot water setting. While turning on the machine feel of the hot water line at the machine and see if you notice a buzz or feel a click as you turn on the machine. On this setting does water run in and is it hot or cold. If water runs and it is cold try going to a total cold setting and see if you get cold or hot water. Is this a new setup or has it been working and stopped? If new, you could have the hoses connected backward. If you get water in both hot and cold settings but cold both ways then your hot water heater is not working....let me know....
Feb 10, 2008 | Frigidaire FEX831CS Top Load Stacked...
No cold water regardless of setting
2 things it can be if your water pipe were you connect the hose too under the sink has a plastic turn handle to switch the water back on then it is most likely that it has sheard inside it undue the screw that holds it on pull the plastic cover off and with pliers turn until you hear the wate rcome through if not then it will be the solenoid inside your washer that has become faulty were the pipe connects to m8
Sep 24, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
19 people viewed this question
Sal De
fordexpert
Robert Rankin
