Whirlpool LSB6200KQ Top Load Washer
Problem for Whirlpool LSB6200KQ Top Load Washer
Stuck in cycle...
By Sam Ford on Apr 11, 2006
Hello
My Washing machine will not pass the wash cycle and is full of water. It will not rinse or spin or respond when the dial indicates anything past an initial wash. Can I fix it myself or is it at all fixable?
Thanks.
Best Solution
posted on Sep 13, 2006
Very Helpful)
harley12
Rank: Master
Rating: 81%, 296 votes
harle... indicated that his solution for
15864 / 15862 Top... Problem
is valid for all Whirlpool Washing...
I have the same washing machine. I had the same problem you have. My problem was the timer. It just stops at that one position.
If you can slowly move it yourself and it starts to do something after you turn it a little bit then your timer is burn up in that one position.
You have to replace it. You cannot tear it apart and try to fix the timer. It is sealed by the factory.
UNPLUG THE ELECTRICAL CORD.
Take the back off of the panel at the top. Then you will see where the timer is bolted on. Remove the timer and take it to your nearest Kenmore dealer. Make sure you write down the serial and model number off of the back of the panel you removed. They will need it to get you the correct part.
You can sometime find some small companies that carry household appliances. They can order it for you at a cheaper price.
Was this helpful?
Yes
No
Solution #2
posted on Sep 10, 2006
Very Helpful)
pokkathil
Rank: Apprentice
Rating: 100%, 4 votes
pokka... indicated that his solution for
Speed Queen AWS53NW... Problem
please check your timer . the timer motor may be bad, if it is so you have to replace it or rewind the coil
Was this helpful?
Yes
No
Solution #3
posted on Apr 11, 2006
Helpful)
dovi
Rank: Guru  Whirlpool Expert
Rating: 88%, 2516 votes
The problem you described, is fixable and to my opinion, you can fix it by yourself.
Check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely(frozen or stiff)replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you replace the belt.
If the motor isn't running, the lid switch may be defective. In this case, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Was this helpful?
Yes
No
Solution #4
posted on Jul 04, 2008
Not Rated)
uyg5
Rank: Apprentice
Rating: 0%, 0 votes
I just found this page because I was having the same problem with a coin-op machine in my basement (thus no settings to change). I resolved the problem by opening the lid and grabbing the center piece and shaking it back and forth as hard as I could.
Problem solved for today.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool LSB6200KQ Top Load
Questions and Unsolved Problems for Whirlpool LSB6200KQ Top Load
Do you recommend Whirlpool LSB6200KQ Top Load Washer?
Answer
Answer
My Whirlpool works in every way but will not spin.
Answer
there is a clicking sound throughout the wash and rinse cycles. daja
Answer
the washing machine doesnt spin or work anymore as normally
Answer
roper washing machine squeaks loudly on spin and rinse cycle. How can ya fix it?
Answer
My washer gets stuck on the fill or rinse cycle. It's not the switch. We just replaced our old... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
