Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile PSC23SGRBSS (Artica)
No lights in refrigerator panel except for blinking HRS light....no temp lights and the entire water/ice, etc panel dark too......this unit is 4 years old....could someone help, please?  Thank you
  • moosewoman00 Sep 16, 2008
    Can anyone help please?
  • ssamis Dec 29, 2008
    I have the same problem - were you able to fix your issue?
SOURCE: ge profile artica refrigerator/freezer won't
The refridgerator was in showroom mode. I just unplugged it and plugged it back in, to correct the problem.
Posted on Jun 27, 2008
Sea Breeze
  • 4654 Answers
SOURCE: GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Posted on Jul 27, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ge profile artica ice dispenser and chute frosing.
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Posted on Oct 21, 2009
Testimonial: "new here--did not mean to rate you low..sorry!"
aasc
  • 1606 Answers
SOURCE: GE Artica, pulsing lights
Your refrig display , has lost communication , with the main control board , located , behind the refrig , behind an 8 " X 10 " panel . The control board , is easily replaceable , with 7 or 8 plugs , attached to it . The part number , for your board , is WR55X10942 . It runs about $150.00 .
Posted on Dec 09, 2009
Testimonial: "You confirmed what we thought was the problem. Thank you for taking the time to respond!!"
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
I have a GE Profile refrigerator Model # PSC23MGTC it has an Artica Water & Ice dispenser on the freezer door, the ice will not come out, and noew the water works only when it wants to, I think I need...
Cut and paste this Factory Service manual for your refrigerator.
The troubleshooting guide will help locate the bad part.
http://appliancejunk.com/ge/refrigerator/31-9072.pdf
Aug 08, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Dec 09, 2009 | GE Profile¿ Arctica® Energy...
GE Profile Artica icemaker does not make ice. model # PSC235GNA. We still get cold water .
use a thermometer make sure freezer is normal operating temp if freezer is cold enough and water is filling ice maker you may have bad ice maker very simple system make sure your getting water 1st thing to check is for water if you have water and freezer is cold youll have ice
Aug 18, 2009 | GE Refrigerators
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Artica
The main PCB at the back of the appliance has failed
Nov 12, 2007 | GE PSS25NGM Side by Side Refrigerator
Ge Profile dispenser panel
Here is a link that will help give you a step by step process of elimination, click below and insure you have the correct model numbers as you move through the process, Thanks Sea Breeze
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Oct 26, 2007 | GE Profile PSI23NCR Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
232 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
