Compal CY27 Hi can you please help me ---not sure how i go about disabling BIOS memory such as caching or shadowing played around with dos when i had a mate into the bcc pc 25 years ago just got back into them but could do with some help cheers mark
    Genius:
  • 1,239 Answers
Hi sir  use your manual or maybe boot into windows (if possible) and find out the refresh rate the your lcd screens run at. (LCD's are locked to a single refresh rate and have an optimal resolution unlike CRT's and its usually 60Hz)
since we're going to mess about with your display configuration, it would be wise to make a backup of things.
exit X and go into the plain black console.
cd /etc
cp inittab inittab.old (make a backup of inittab file)
edit the inittab file using vi or any other editor and change the default runlevel to 3 from 5.
save the file and exit.
Posted on Sep 11, 2008
  • 1,879 Answers
Reboot!
on boot time watch for any message that sez anything about going into the BIOS and displaying what key to press. For example: Hit Delete, F2, F3, F4, and so on....
  • 4,472 Answers
Do you know how to get into the bios setup? Either hit delete or a function key then you can change the settings in there.
Thanks,
Lee
Posted on Sep 10, 2008
  • 6,487 Answers
You can try to access the BIOS of your computer and there you will see all the option that you can change on your BIOS and hopefully you will be having some option to do that on your BIOS...
Hope that helps...........
    Guru:
  • 1,894 Answers
If there is a option it can be seen in your bios. You'd have to consult the manual that came with your computer. There
are several different manufacturers of CMOS chips, as well as a great
many versions of each BIOS.
  • dewan nafees ahmed Sep 11, 2008
    These controls are located in a part of the system called "BIOS Settings", "BIOS Menu", "CMOS settings", "CMOS setup" or some similar variation. This should be covered in your user manual.
    You usually enter "BIOS Settings" menu by pressing a specific key or keys during the beginning of the boot-up process. The specific key(s) to press are usually mentioned in a corner of the display as the system boots. They should also be in the manual. It is sometimes the "F2" key, or "Del", or a combination like "Ctrl+S" keys.
    Once you've entered the menu, you'll see it provides many parameter settings organized in "pages". Basically, walk through the on-screen prompts until you see the settings having to do with cacheing and shadowing.
    Every system and even current BIOS version has
    a different way to present these data, so we generally can't give you a
    specific keystroke-by-keystroke set of instructions. Again, your user
    manual should detail this information.
    If you don't have a current user-manual, you should be able to go to the motherboard or system manufacturer's website to download a copy. It will usually be in .pdf format which will (in order to be able to read it) require a free .pdf reading application like Adobe Reader or Foxit.
2 Suggested Answers
  • 1894 Answers
SOURCE: UNMOUNTABLE_BOOT_VOLUME CY27 COMPAL
read this. this would help you
thank you
It stated on my lappy " UNMOUNTABLE_BOOT_VOLUME" "check to make sure any hardware or software is properly installed" and ask my hardware or software manufacturer for any windows...
UNMOUNTABLE_BOOT_VOLUME - Windows is completely corrupted and the BIOS can't load it.
Just load the default settings in the BIOS and then reinstall Windows using the recovery cd that came with it when you bought it.
Jan 14, 2011 | Dell Inspiron 9100 Notebook
Hi. Do you know where I can get a 512mb ram for my compal cy27?
Try here
www.crucial.com
I have bought from these guys loads of times. They are pretty cheap with fast delivery and you can also check your pc on this to see your max memory...Hope this helps...
Nov 16, 2009 | Computers & Internet
Will removing the CMOS battery clear the BIOS
it's about the processor level caches
but also might be a bad memory slot (RAM)
resetting the bios is a good choice, maybe this will helpe either
Jul 01, 2009 | Acer Computers & Internet
Blue screen on my P.C.,windows shut down
If you are using an AGP or PCI graphic card try disabling the on board video adapter from BIOS.
Ensure that you have the latest drivers for this video card installed.
If the video adapter is using shared memory, then you may have a faulty RAM module.
Reinstall Direct X and any graphic acceleration software.
Go to BIOS and disable memory caching and shadowing options, this usually does not solve the problem, but you never know.
Contact video card or Motherboard manufacturer, there may be an issue between video adapter and your motherboard, or the specific software that you are using. In that case manufacturer may require to download a patch.
May 16, 2009 | Palit Microsystems GeForce 8400GS,, PCI...
Why Disable BIOS memory options such as caching or shadowing ? and how to disable it in bios ?
This particular error would typically indicate a problem with memory mapping associated with a peripheral device. I was unable to locate a hit for okfu53.sys, but most likely this is a device driver of some type. The instruction to disable cache is a holdover from old hardware and operating systems and is most likely not actually applicable- however by disabling it is just two areas that are memory users that you don't need at that point. Frankly I would just reboot. If you see it again reinstall the video drivers.
May 15, 2009 | Microsoft Windows XP Professional
Bios update killed my machine
you disable shadow and caching in bios at boot ...
at startup you need to hit f10 (modeels may vary)to enter setup(bios)
in bios make required changes save and exit.
Jan 24, 2009 | HP Compaq nc6120 Notebook
BOIS reset
I can help you with this without a doubt! Good to see you getting back into the field. The first thing I need to help you with your problem is the manufacturer and model of your computer in question. The second is a little more description on what you would like to achieve. For example, from the BIOS you can enable or disable functionality for CPU's, disable checksums or reconfigure voltage settings. If you want to just poke around a little bit I can give you hand with that too.
Sep 10, 2008 | Sony VAIO VGN-FS640W Notebook
Bios memory options
try pressing F2 and DEL key rapidly after switch on until you get a BIOS or password request
Aug 08, 2008 | EliteGroup P6ISA-II Motherboard
Computers & Internet Logo
424 people viewed this question
David Payne
David Payne
