Question about Samsung Digimax i5 Digital Camera
Shutter operation fault
Shutter not operating by pressing Power on button.Screen is switched on for few seconds only. So not able to take any pictures.
    Champion:
  • 277 Answers
Hi first of all change the battries then if it dosent work give it a little slap when you hit the ON it will help the mechanics work good luck
Posted on Apr 17, 2006
I have a taylor ice cream machine thats keeps a constant beep even when ice cream is ready model 339-27
I'm not 100% on this model but here goes....
A "beeping" tone will sound to alert you
of a fault.
To discontinue the tone, access the Operator
Menu and enter Option B. Correct the fault, then press
the OFF (<--) key, and the tone will stop.
FYI Fault Description
(Option B)
This option lists any faults detected by the control and
allows the operator to clear them from the system.
When a fault is detected it will be displayed on the
second line of the LCD. Pressing the MENU/SEL key
will display the next fault found or return the display to
the Operator Menu if no additional faults exist. If the
OFF key is pressed when a fault is displayed, all faults
that have been corrected will be cleared from the LCD
upon returning to the Operator Menu. To return to the
Operator Menu, press the MENU/SEL key.
for 337.....
Screen display.....
The POWER SWITCH OFF screen indicates that the
power switch is in the OFF position.
POWER SWITCH OFF
The normal operating screen will display the current
mode of operation and the level of mix in each mix
hopper. (The power switch is in the ON position.)
MODE: OFF
MIX:
L = OK
Operator Menu
_________________________________
The Operator Menu allows the operator to access
operational information and to set non-critical
functional parameters. The Operator Menu also allows
access to the Service Menu. (Note: Only service
technicians who know the access code may use the
Service Menu.)
Operator Options
A
Exit From Menu
B
Fault Description
C
System Information
D
Current Conditions
E
Service Menu
Pressing the OFF (<--) key will move the cursor one
position to the left. Pressing the STBY (-->) key will
move the cursor one position to the right. Both keys
include the "wraparound" feature. This means that
when the cursor reaches the end of the option, any
further movement in the same direction causes the
cursor to "wraparound" (to be placed at the opposite
end of the option listing)
here's the manual if you don't have it....
http://www.taylorfreezersales.com/op_man/0337op0.pdf
Best to you hope this helps a little
Mar 05, 2018 | Taylor Ice Cream Makers
Hp pavilion zd8000 keeps restarting never even getting to the start operating system
First step: Clean up the air vents (inlet and outlet) and the fan. You can use canned air to clean it up.
Second step: Use Windows media (DVD) to reinstall the operating system (it will fix the boot up problem).
If the problem persist: use a good working hard drive and install the operating system from scratch.
Mar 09, 2014 | HP Pavilion zd8000 Notebook
Shutter does not operate.
hiwhen you say shutter does not operate, it mean too general to answer. could you provide more detail?I will give how does shutter work. First, you press shutter button, it will activate two switchs (one is focus and meter and the other is release ) Second, mirror goes up and opening shutter curtain move up. Third, closing shutter curtain down and mirror down and picture come out. Of course there is also aperture control unit sequence.
Jun 04, 2011 | Nikon D40x Digital Camera
My optio s10 ..as I switch on the lensa is working well, in lcd i see nothing , it's focus...but only black lcd i got every shot the shutter .
Many cameras have a button that switches the lcd screen off. Is there a chance that you may have pressed it by accident? it will be a button with a picture of a box with a vertical line either side of it or LCD/VF written on it. try finding that button and press it once, the screen should come on after a few seconds. If this doesn't work then I suspect there is a fault with the camera.
Good luck.
Jan 20, 2011 | Pentax Optio S10 Digital Camera
How do I reboot my acer laptop with my copy disk?
When turning your laptop on, before Windows starts booting, a splash screen appears first (usually with the logo of the manufacturer). Look on the splash screen (usually at the bottom) for a key (usually F10 or F11), assigned for System Recovery CD/DVD with the laptop. or 1.Press the start button from the start menu depending on your operating system(win 2000,xp) 2.Press Ctrl+Alt+delete combination from the keyboard. 3.If you have a power button on your laptop keyboard,it could also be useful by pressing and hold it down for few seconds N.B: "Ctrl+Alt+Delete" can exit you from usage and trigger a reboot or shutdown. Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up. Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot. Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately. Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually. A few seconds should do unless you have additional problems.
All the Best!
Sep 12, 2010 | Computers & Internet
When i press the shutter button to take a photo the shutter goes up and the power goes down. i have to remove the battery (sometimes wait a few seconds) reinsert it and then the shutter closes. It does not...
If your camera battery is having limited current factor, there is a possibility that the entire action is not happening with the available voltage/current. as multimeter test of voltage might indicate the voltage but the current factor will need a series test. hence I advice you replace the batery and test again. If the fault recurrs then the camera electronics is at fault, possible that the shutter mechansim is taking up power and stenching the cirrcuits to hang up. I feel the camera has to be open out to confirm the power hang.hope I could help.? Good day
Jun 25, 2010 | Cameras
My shutter will not open. The power button presses in and nothing happens. I have since got a new battery that was the problem, shutter still will not open. Camera is not operative, please...
Can you get any signs of life? playback pictures etc? Try pressing the playback button instead of the power button. If camera display works then press the picture button and see if the camera will switch over and the lens extends. Also check if the tab on the battery door is not broken. This operates a micro switch to cut off power
Jun 19, 2009 | Fuji J150w Digital Camera
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Automatic off
Common problem on 7610 and other nokia symbian. If nokia logo blink more than 3 times after power on the phone, that's a software problem, ( phone wont boot to its operating system ).
You can try to hard format the phone. Here the way , press ( *,3 ,and call ) buttons togeteher while you pressing power on key. Hold on about 15 seconds till nokia logo blinks 1 time, and formatting message appear on LCD screen.
If dont work, you must reflash ( reinstall ) the operating system using proper repair tool and software, many service shop in asia have this tool.
Jan 14, 2009 | Nokia 7610
How do I set a shutter delay on a cx4230 camera?
It is easiest to link you to your camera manual.
Click on:
Kodak CX4230 Manual
Go to page 20 in the manual for instructions.
While you have it open, save a copy to your computer for future reference.
Here it is if you don't want to do that:
In Capture mode, press the Menu button.
Highlight Self Timer , then press the Select button.
Highlight On, then press the Select button.
Press the Menu button to turn off the menu screen.
Place the camera on a flat surface or use a tripod.
Press the shutter button completely down to take the picture.
The red Self Timer light turns on for 8 seconds, then blinks for 2 seconds. The picture is taken.
Dec 24, 2008 | Kodak EasyShare CX4230 Digital Camera
Samsung Digimax i5 Digital Camera Logo
61 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
