Question about Danby Heating & Cooling
Water fill light stays on all the time and compresser will not come on
Water fill light stays on how can I fix this problem ?There is no water in the internal tank or the external tank.Please help
Posted on Sep 11, 2008
LIght on box inside flashes 4 times on a new propane fill up
If the gas was empty for three days, the furnace may have attempted to start numerous times causing virtually ALL residual gas in the incoming line to be drawn out. You may consider purging the gas line at the clean out cap where the gas line enters the furnace. However, it should have restarted and stayed running after just a few times at the most because as long as the line was NOT disconnected from the main tank, there should be NO air inside the line to cause flame failure.
I'd suggest asking the service company to double check the furnace manifold pressure to ensure there is not a regulator related problem.
Three times this winter (on the coldest days no less) a tiny droplet of water froze internally of the regulator right on the orifice blocking gas flow.
Feb 16, 2015 | Intertherm Gas Furnaces - M1GB-056-AA
When I turn on my unit the cooling light flashes but nothing happens
Your unit may have a wall control which can set the Evap cooler to a pre fill mode time which fills the base with water then there is a pre wet mode which starts the pump to wet the pads. After both these functions have completed the fan will start. This could take up to 4 minutes before the fan starts and can be programmed out if not required.
Nov 25, 2014 | Heating & Cooling
When i compress the propane knob for the pilot light, the whole element has propane run through it. Then when i let go of the pilot to run gas to the element, the flame goes out...? Pls help. Its brand...
Hold the knob down for at least three minutes after lighting the pilot. This give the thermocouple plenty of time to heat up and should stay lit.
Sep 04, 2011 | Heating & Cooling
Red light coming on ; tank is filling up. I drain
Fortunately, from what you have described, the unit is working as it should. But, the frequency that it's occurring is what I think you're concerned about.
If you are operating the Dehumidifier Mode along with the Cooling Mode, this will generate more water in the tank and require more frequent draining. Running the Dehumidifier and the AC (Cool) at the same time is not recommended. It reduces the cooling capacity of the AC Mode and generates heat in the room. And, as you already know, more water.
Hope this helps you and thanks for choosing FixYa.
Aug 03, 2011 | Haier CPRD12XC7 Air Conditioner
My amcor air conditioner is leaking water all over the floor. I drain it and it will only last less then 24 hours till it turns off, leaks all over an needs to be drained. Help!
I figured out the problem. My Amcor portable started leaking after the fill light came on for the first time in years. After doing some research I saw that it uses the water to cool some other part of the system to evaporate out the exhaust. So I took the ******* apart and messed with things. Finally I started pouring water into different trays and noticed it would not drain down from the top tray even when running. So I removed the top part and found the drain hole. Blasted that sum ***** with some compressed air and WAMMO it works again.
-madmanmarz
Jul 06, 2011 | Amcor PLM-14000E Portable Air Conditioner
Do I need to replace the thermocoupling on my Reliance 501 gas water heater? Model is 5 30 NOMT7 C. Recently, I've noticed an intermittent problem with the the hot water not staying consistent. So we're...
The thermocouple is a safety for the gas valve. It tells it the pilot light is lit. If your pilot light is not going out and the burner fires when you turn up the thermostat, it is all working as it should. In other words, if you don't need to re-light the pilot, your thermocouple is OK. Turning up the temperature of the water is a good idea, just be careful not to burn anyone with the hotter water. You mite want to try a water saver shower head. Some don't throw enough water to get the soap off, but I bought one that can be turned to adjust flow and we have been happy with it. If I missed what you need from this, please let me know. Roger
Apr 10, 2011 | Heating & Cooling
The water pressure dial is reading 4, there is water dripping from the overflow, but now boiler fires up, sounds like it is lighting but then dies off, any suggestions, it is an ideal response 80.
there should be around 15-20 lbs of water pressure if the over flow is leaking check the expanson tank. if not enough water going out on high temp. Also check the auto fill/ manuel fill
Aug 28, 2010 | Heating & Cooling
Enviracare EWM 300W the water fill light comes on when I know the unit is full
u should have a float switch where the water goes in at it has an arm usually that raises as the water fills and it makes up a switch make sure it is raising and not syuck if it is raising the n the switch is probably bad and needs replacing u can see if is the switch by jumping the 2 wires together and see if the light goes off thatll tell u that the switch is bad
Feb 23, 2010 | Heating & Cooling
Water fill light stays on all the time how should I slove the problem?
There should be a sensor that measure's the water, some work with a float and get's stuck,if so you can just push it down again,if it does not have a float the most possible cause is that its broken and need replacement.
If you don't know much of a a/c unit better get a repair man to have a look for you.
Regards.
Wouter.
Sep 11, 2008 | Danby Heating & Cooling
Heating & Cooling Logo
185 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
CheckitRight
CheckitRight
Tim Whalen
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
