Question about Maytag Dryers
T5 error code on dryer - Maytag Dryers
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: t5 error code comes in my amana dryer ned 7200tw
That is actually a Ts error.
Thermistor Short Sensed
The Thermistor resistance is very low.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Thermistor is Item #27 HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 07, 2010
Testimonial: "very very good"
  • 53 Answers
SOURCE: dryer has a t5 error code and won't start.
There should be two or three screws at the back holding the top on. Take these out and slide the top back and off. Inside should be a service tech sheet that will tell you what the code means and what to replace or check. Once the top is removed it shouldnt be hard to see how it is disassembled.
Posted on Jul 08, 2010
Jahn27
  • 1554 Answers
SOURCE: Dryer will not start get an error code that looks
It is actually error code "tS" which stands for thermistor shorted. The control interprets it as an extremely low resistance which is a result of a the dryer overheating. Locate the thermistor on the blower housing and replace it. Click on the link below and refer to the parts diagram then look for item number 27(thermistor).
Amana NED7200TW Electric Dryer Bulkhead Parts
Click on the link below if the error code still appears after replacing the thermistor.
Persistent Error Code "tS" on Amana NED7200TW Electric Dryer
Posted on Aug 22, 2011
Samsung vtr error code t5 what is it
"Ts" error code usually indicates restricted air flow in the vent (could be internal or out of the dryer. In some cases could be the thermistor itself that gives out false reading.
Feb 11, 2015 | Samsung Dryers
What is error code t5 for dryer # NGD7200TW
It is actually ts error code, it is for your thermistor.
Aug 26, 2014 | Dryers
NED7200tw t5 error Code
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Aug 08, 2012 | Amana NED7200TW Electric Dryer
Dryer runs for 10 seconds amd then stops. code t5 comes up
Thermistor Short Sensor
Check for:
Oct 08, 2011 | Dryers
Dryer will not start get an error code that looks like a t5.
Aug 21, 2011 | Amana NED7200TW Electric Dryer
T5 error code
e5 code have replaced thermister
Jul 24, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer has a t5 error code and won't start.
Jul 08, 2010 | Maytag Neptune MDG9700A Gas Dryer
T5 error code (Model MDG9700AWW )
turn power off to the dryer for a few sec and turn it back on and see if it clears
Aug 24, 2009 | Maytag Dryers
Dryers Logo
107 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
