Question about Microsoft Xbox 360 Console
Xbox wont turn on
When i turn it on a red light appears around the power button and it flashes
    Scholar:
  • 42 Answers
RRD - Red ring of death, caused by the processor recieving to much heat.
Ebay.com sell tools to fix this but I am unable to gaurentee anything.
If its going around in a circle flashing then that is your problem.
The fix kits on the net run about 20 dollars and take 30-45 min to do..
and include instructions on how to use the toold, and place the new heat washers
heat silicon silver and how to put back together.
Youtube.com also has videos on how to repair.
Good luck
Posted on Sep 11, 2008
Evry time i turn my x box on the rim of lights around the on button shines red and wont out put anythik
If all lights in the ring are red, turn off the xbox and ensure all of the power and Audio/Video cables are fully inserted in both the xbox and your television.
Feb 25, 2011 | Microsoft Xbox 360 Console
How can I fix "Red ring of death" on my XBox 360
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death" or "Red Lights of Death" or "Red Ring of Doom"), instead of the one to four green lights indicating normal operation, represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the hardware failure occurs, or not at all. If the console freezes occasionally, the error will not necessarily follow. The technical problems seem to affect some generations of consoles more than others. e.g. Xbox 360 60GB This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console. The 3 flashing lights can also be caused by power surges; if the console is connected to an outlet that receives a power surge, it may have a failure and the 3 lights will appear as long as the console is plugged into the outlet. Turning off the console, unplugging all power cables and plugging them back in, and restarting the console will fix the issue in this case. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
An incomplete red ring circle appeared
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Blinken red light around the power button
hello sir
Solving Your Red Light Flashing:
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Fix-shadow
Jul 26, 2010 | Microsoft Xbox 360 Console
Trying to turn xbox on and getting blinking red ring around power button
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
May 10, 2010 | Microsoft Xbox 360 Console
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 24, 2010 | Microsoft Xbox 360 Console
I HAVE 4 RED RING WHEN I TURN ON MY XBOX
Solution
Mar 23, 2010 | Microsoft Xbox 360 Console
Flashing red light
if its three of one red light, its broken and youll need to send it to microsoft for repair
Dec 30, 2009 | Microsoft Xbox 360 Console
Two red and green lights around the on button?
http://ezinearticles.com/?What-Do-Xbox-360-Red-and-Green-Lights-Mean?&id=1981493
Jun 15, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
59 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
