Question about Dryers
LG dryer, model # DLE5977S, no heat, checked filter, exhaust,breakers -- everything works EXCEPT no heat.
  • icycool72 Sep 27, 2008
    I'm encountering the same problem. Drying time is about 3 hours for regular load!
  • 706 Answers
Here is a link to get you a service manual for your washer.. in all probability, your thermal fuse opened.. check page 15 in this manual for troubleshooting techniques.. the thermal fuse ( once opended) needs to be replaced and wil disable power to your heating element... There are a few other checks in themanual you can apply but make sure you identify only those used on electric dryer models. the book contains info on gas models as well.. Hope this helps..
here is the link.. http://136.166.4.200/contents/Laundry/DLE5977/DLE5977_Service_Manual.pdf
Good Luck !
Posted on Sep 10, 2008
My Lg Dle5977s, will not heat up, had new heating element installed and it work at the repair shop, the cooling light is staying on
Check power to both legs of you 220 v outlet.
Cooling light always stays on-not an issue.
Sep 01, 2017 | LG Dryers
Not drying no heat...checked the breakers and everything OK, what should we do next?
check the exhaust vent tubing first
If lint has a build up the moister sensor will keep the heat at check
Jun 07, 2010 | LG DLE2532W Electric Dryer
I have the LG DLE5977S dryer. When I push the
The belt could be broke or the idler spring may have come of in either case you will have to take the machine apart to find out which.
Mar 21, 2010 | LG DLE5977 Electric Dryer
Lg dle5977s will not get hot
Check thermal fuses around the heating element.
Dec 01, 2009 | LG DLE5977 Electric Dryer
MY dryer won't heat
Check the dual-breakers for the dryer in the house electrical panel--push off, then on. If no help, then the heating element(s) in the dryer may be burned out or the internal thermostat is defective, both of which are accessible after removing the drum. After repair, vacuum out all air ducts including the hose to the outside. Also, wash the lint filter in hot water and detergent to remove fabric softener deposits that block air flow.
Nov 15, 2009 | LG DLE2532W Electric Dryer
Dryer won't work say's clean filter but it is clean electric dryer lg model dle5977s
clean the filter and the front air duct assembly go to AppliancePartsPros.com and look at the diaphram.
Oct 10, 2009 | LG DLE5977 Electric Dryer
NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
May 29, 2009 | Whirlpool GEW9250 Electric Dryer
Amana dryer wont dry
Replace that square white one and it should start working.
Jan 12, 2009 | Dryers
2008 LG Dryer will not heat.
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 11, 2008 | LG DLE5977 Stainless Steel Electric Dryer
My LG Dryer DLE5977S is heating but not drying. Also, the check filter light continues to blink even though it's been cleaned repeatedly.
it is probably the exhaust system. you need to take it apart and inspect every inch of the inside of it
Oct 27, 2008 | Dryers
Dryers Logo
319 people viewed this question
Top Dryers Experts
