Question about Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750
We have a xerox 7750DXF that sat a while in storage. Now when I try to print I get a message: Laser Unit Failure...If persists, call service. Code 10.
Phaser 7700 removed from storage.
getting bad color mix on printout.
seems all colors are dull and smeared.
already replaced all toner cartages.
Posted on May 27, 2010
Same issue here with a 7750DN. Came out of storage with error 11. I would like to remove ours. Can you tell me how?
Posted on Apr 08, 2010
  • 2,072 Answers
There is a motor in the laser called the polyogon motor, It turns the mirrors in the laser.
It most likely is not starting fast enough.The laser isnt that hard to remove. But if it has failed, it is pretty expensive.
Let me know if you want to attempt to pull it.
Posted on Sep 20, 2008
I have xerox phaser 7750 by mistake i bought 7760 yellow toner shall install it to 7750
Not yet, check with the supplier and ask if it is compatible with the 7750, if not then exchange the 7760 for a 7750 yellow toner cartridge. Once you open the cartridge the supplier will not exchange.
Apr 22, 2013 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750 - Tray 1 streaks on prints
If you put Tray 2 in Tray 1's spot with the heavy stock in Tray 1 (now in tray 2's spot) and print from it, does the problem persist?
This may help...
May 16, 2017 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750 error code 14 & 15.
try to hold down the on/reset button a few seconds when you power it up ...on most printers this resets them ..about 10 sec it is enough ...
Nov 26, 2009 | Office Equipment & Supplies
Print quality problems after installing imaging unit.
Put the old image unit back in, if it prints normaly then you might have bought a defective image unit.
Apr 16, 2009 | Xerox Phaser 7750GX Laser Printer
Xerox 7760 GX squishing print jobs vertically
you need a snippet {software patch installed}call .xerox support
Mar 13, 2009 | Xerox Phaser 7750GX Laser Printer
Xerox Phaser 7750 parts
Google " the parts drop" . Call Britt and see what he has. He should have one of those.
I don't work there but you will never find anyone better to deal with.
Ahh here is his phone number 201-387-7776. Tell them Rick said Hi.....
Jan 06, 2009 | Xerox Phaser 7750DN Laser Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
116177400 1 *KIT IBT - UNIT
1. Clean feed rollers, exit rollers and guides; replace if
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 7750DN Laser Printer Logo
262 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
