Question about Frigidaire Affinity ATF7000E Front Load Washer
Model atf7000es1 front load washer
Every time the washer discharges water I get a stinky sewer smell from the discharge hose. I have had a plummer out to check my sink trap and its totally find. Turn on the reg. hot/cold water from the facuet and never any smell. Whats going on!!!
  • 706 Answers
You may want to run a simple test to see where the problem lies..
First off.. remove the washing mshine drain hose from the house drain and put it into a clean barrel ( plastic trash barrel will work fine as long as it doesn't leak water and is at least 20- 30 gal size). Then run a wash cycle and capture the water in that barrell.. Once you get the drain water into the barrel, do you notice the sewer smell there? If so, then you know itis being generated by the washer.
Mildew and mold have plagued most, if not all front load washing machines and there is no 100% cure. There have been many suggestions to minimize the problem.. such as : leave the door open to air out the washer after a cycle ( if you do this, make sure you don't have small children that could get trapped in the washer). you can also wipe the gasket around the opening of the door after each wash ( including all nooks and crannies that could retain standing water that would otherwise develop mold etc), another way to minimize this problem is to use an aftermarket product like AFRESH ( sold at home depot and other stores) that you cycle about once a month to reduce mold growth etc. The fundamental flaw with front load washing machines is they need to be water tight via the front door and to accomplish that, the gasket configuration retains waste water. Left in a closed container like the washing machine, mold will develop. If you are certain that the source of that stinky sewer smell is the washing machine outflow of water than you can disregard the first part of my suggestion and not run the water into a barrell and go directly to the other known improvements... Hope this helps..
Posted on Sep 10, 2008
  • 374 Answers
If the trap is fine I susupect your vent is probably restricted. If you have an inline vent ( a spring loaded rubber diaphram device at the top of the vent pipe) this part may have failed and need replacing if not have the plumber come out and rod the vent stack for the washer itself. If you are new to the area you may have a dual water system where the washer is ran off of a well and the rest of the house off a filtered source. The washer may have also been tied into a water header prior to the filtration system. In the Southern part of the US there are swampy areas that have shallow water wells that have a high sulfur content and give off the odor of rotten eggs, as I do not know your location this could be true also.
Hope this helps you.
Why does it some times smell like a sewer?
You could be getting reverse flow though the discharge line. Also, if the discharge line is connected to a standpipe, you may be smelling sewer gas.
Jul 02, 2015 | Kenmore Washing Machines
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
Strong Odor, almost organic smelling, coming from my Fridgidaire Energy Star stacked Front Load Washing Machine, 5 cycle, Heavy Duty Model# FTF530FS1, Serial # XC90201067. It is in the townhouse that we...
This smell usually comes from items caught in the hose. If you can remove the bottom front panel, (usually 2 screws holding this down) then you will see a rubber acordian piece attached to the water pump. If you remove and clean this the smell should not remian. I just removed mine and found many coins and a huge ball of stinky lint, hence the smell. Good Luck!
Jul 21, 2011 | Frigidaire FTF530FS Front Load Washer
There is a terrible smell from my washer
Hi, what happens is that water sits at the bottom of the discharge pipe, as well as a build up of "gunk", which is a great breeding ground for bacteria and such. So during the first rinse out, the smelly water and gunk is discharged into the drain, and the smell comes up from the laundry tub drain. Pour a few cups of bleach into the discharge hose and let it sit for an hour. This will kill all the nasties. Then just run the machine once through to pump out the bleach.
Sep 09, 2010 | KitchenAid KHWS01PMT Front Load Washer
Water will not drain out of washer
Disconnect the discharge hose from the washer and look for a clog at both ends of the hose. Also, look down where the discharge port is on the washer and clear out the clog there also. If you see no clogs, then make sure your discharge hose is not crimped at such an angle to prevent water from flowing through. Also, make sure your discharge hose is not running on the floor and that it goes vertical straight 4.5 to 5 feet from the floor and then loops directly into the discharge pipe. Give that a shot. Still no water drain? Then the water pump needs to be replaced.
Feb 19, 2010 | Kenmore 80754 Top Load Stacked Washer /...
Mildew inside bellow.
is this a question? I will assume that you are saying that there is mildew growing below something, possibly the drum, inside the washer. The only way to definately get it out is disassembly and thorough cleaning. Check your discharge hoses to make sure they are not clogged, leaving water in the washer rather than discharging all of it. If you want to kill the mildew/smell, run an empty load or just some rags but throw a cup or two of bleach in the washer. The chlorine will kill the mildew growths. Run a rinse cycle or two before your next load of darks to get the chlorine out (especially if you are having a discharge problem) so you don't inadvertantly bleach your clothes.
Aug 21, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a Kenmore 'Elite' front loading washer that stinks
Have you been leaving the door cracked open after washing a load? If not, mildew will form and smell. If you have, then it would be something else. Respond with any questions.
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
Stegnant water smell
It should completely empty the m/c.
If it is plumbed into your sink waste this could be cause of smell, also if it is connected to your waste make sure the hose is above the bottom of the sink trap,as water can sometimes syphon back into the washer from the sink. Remove hose from sink connection and clean and check for obstruction.
I doubt your pump is faulty.
If it goes into a stand pipe make sure this is not partially blocked, and again clean stand pipe with a strong disinfectant or similar
Plz rate my solution.
Thanks.
Dec 21, 2008 | Hotpoint VVSR1070D Top Load Washer
Dryer won't dry
I also have one for several years now.
I also had problems with dry function at first.
If your washer is still covered by warrenty, call them. They were very friendly and helpful and came out and made service call at no charge.
My problem was that I had attached the discharge hose to an existing discharge pipe that connected to the sewer. This pipe was too narrow and burned out the condenser.
Also, try cleaning out the lint filter on the lower right side of front. Put a cookie sheet under the opening to catch about a cup of water that will come out.
Good luck,
wsf
Mar 30, 2008 | Malber WD1000 Front Load Washer/Dryer
Frigidaire Affinity ATF7000E Front Load Washer Logo
337 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
