Question about RCA WSP155 Main / Stereo Speaker
Can't correctly connect speakers.
The TV went to the shop for repairs. We can't find our manual and have been unable to correctly reconnect. HELP.
    Problem Solver:
  • 7 Answers
Just plug the transmitter into the headphone plug on the computer, tv, radio or whatever you're using, and then plug the transmitter & speakers into the walls. That's all!
Posted on Aug 28, 2009
I am getting no sound out of my Panasonic Viera TH-50PX80U Plasma TV
Are the speakers' cables connected correctly? (p. 37) Is "Sound Mute" active? (p. 13) Is the volume set to the minimum? Is "Speaker output" set to "Off"? (p. 22) Change "SAP" settings. (p. 16) Check "HDMI 1 in", "HDMI 2 in" or "HDMI 3 in" settings. (p. 22)
Hope this helps, page# refer to your manual.
Feb 14, 2015 | Panasonic Viera TH-50PX80U Plasma TV
My Samsung DLP HLR5667W went blank. Just before it went out, I was unable to control volume/mute. I replaced the lamp ($175 a Walt's ripoff shop) and the TV worked for four hours then died again
I would guess that it could be the main board going bad. Check all our connections and wiring. You should call places like Tri-State Module and they can probably send you a part or repair for way less than 500 bucks.
Mar 31, 2013 | Samsung HLR5667W 56" Rear Projection HDTV
Thompson 46RH2LPS firstly by sound on the TV went off there I was using an external speakers for the sound for approx 04months, All of a sudden the power went off on my Projection TV set. the engineer...
Hi Mahesh Nagarajah,
I don't have the copy of the service manual on my collection on this model no., I've also checked my links online but this is currently not available. May you please double check the model no. and chassis no. of your unit.
May I know also if your unit is totally dead set (no indication of led light at the front panel), it will help diagnose where the fault came from.
Jdvillanueva
Sep 28, 2011 | Thomson Televison & Video
I have a panosonic plasma tv when i switch it on it tell me there is a speaker short and then switches it self of model number pdp507xda help
It's the internal circuitry problem. Try muting it and put audio connection to other speakers if it repeats, your TV audio system is internally dying.the audio connections has to be checked and faulty components should be replaced.
1. Speaker short.
Open it up and check the speaker connections. ONLY if you have basic skills working on electronics and don't have a warranty.
2. Sound Volume "Leveler"
Look in your sound option menu for a sound "balancer" option and turn it off.
If this doesn't work disable the sound and invest in that surround sound system (external speakers solution of your choice)
try this.for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the audio circuit board are getting short in between so the circuit is not getting completed and cutting in between so the tv starts and turns off. if the tv is connected to externalk speakers then check out without connecting the external speakers and see whether it works.if it works that means tv is perfect.but if tv is having inbuilt speakers that its confirm problem with inter audio circuit of tv.so try connecting external speakers at the back of tv and check out.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 20, 2009 | Panasonic PDP-428XDA 42 in. Plasma TV
I have 2 psw810, and one of them are blown. how can i get it repaired. felixflor216@hotmail.com
Generally speaking if the voice coil is actually 'blown' (accepted too much power therefore reads as a short when connected to an ohmmeter) It would be cheaper to purchase a new sub woofer.
90% of the speaker manufacturing price is in the voice coil. The cage, driver and dustcap as well as the surround are inexpensive components.
I would suggest testing the voice coil with an ohmmeter first before you decide what to do. If the meter doesn't read a short then its likely a TV repair shop can reconnect the lead that attaches the terminal to the voice coil.
Aug 10, 2009 | Alphasonik Car Audio & Video
Sound gone from right side on surround sound and right side of tv
could be a speaker too but a channel going out also is a good suspect. I would have this checked by a TV repair shop before going inside with a service manual. I am sure if its a sound channel that a componet jsut went out and can be replaced.
Jun 29, 2009 | Philips Magnavox MS3652S 36" TV
No sound from speakers when tv is on
It is likely that you do not have an HDMI cable connecting your cable/satelite set top box to the reciever. If you you run coxial striaght to your TV you will need a digital tuner and run the audio componet cable to the receiver and picture cable to the TV. Also be sure that TV out is perferably with optical audio. Hope this helps. If not its all listed simply in the owners manual. Try Sony's website if you lost it.
Apr 05, 2009 | Sony HT-SS2000 Theater System
Speakers went out
Unfortunately you will need to take this to a service shop, as this would not be a simple fix. Make sure you get a quote first, so you can decide if it is just as much money to buy a new TV instead of repairing the old one. Also remember that an older TV will have more things going out as time goes on, so even if the newer TV is a little more money - it would be the best investment for you and likely improve your viewing quality as well.
Good Luck.
May 23, 2008 | Sanyo DS31590 31" TV
RCA WSP155 Main / Stereo Speaker Logo
203 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
