Question about Whirlpool Duet GHW9150P Front Load Washer
Balancing the washer on the pedestal
Duet sport hg
  • 750 Answers
Yes, ljharlow,
What is your Question?
You have a problem balancing the washer on the pedestal??
You must first balance the washer and then put it on the pedestal!
I take it you bought and picked up an installed your own machine.
The delivery men know to do the leveling foirsy and then raise them on to the pedestal
If you have two people you can have one person lift the front of the machine by tilting it back wards on the pedestal so the front goes up in the air a little and the second person turns the adjustable legs till it is level! If you laid the washer on its side ,front,or back at any time since you bought it then you threw the machine out of balance and YOU DO need service to correct this situation!!!!!!!
bless you Huuum
Please rate me on our site for my good advice before you sign off
Posted on Sep 12, 2008
  • Neil Golan
    Neil Golan Sep 14, 2008
    Please give me a "SOLVED" rating at our web site for my pin point advice!
    I'm sure you must be okay now!
    Bless You
Help.....Our duet sport is Very very loud and noisy from start to finish. Made sure it is leveled and balanced. It actually moves on the floor. Friends of ours are having the same problem. This has...
go to walmart and get the swimming pool noodles and put it in between the wall and the washer in between the washer and the dryer and it will help with the noise a hole lot
Jul 30, 2013 | Whirlpool Duet Sport HT WFW8400TE Washer
My duet sport combo shakes like crazy
Suspect your load of clothes is incorrect. Wash large & small items together. Large bath towels, or bath / toilet mats and trainers are notorious for becoming out of balance. As is a 'too small' load as well.
Jul 14, 2013 | Whirlpool 8572546 Duet Sport Stacking Kit
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
Attaching the pedestals to the washer/dryer
You will have to find away to remove the adjustable feet, not an easy job, I would call Sears Appliance Service
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Crankshaft Position Sensor and Camshaft Position Sensor
  1. Serpentine belt from the crankshaft pulley.
  2. Raise the vehicle on a hoist.
  3. Right front tire and wheel assembly.
  4. Right inner fender access cover.
  5. Using a 28 mm socket, remove the crankshaft harmonic balancer retaining bolt.
  6. Crankshaft harmonic balancer using tool J 38192 or equivalent.
  7. Sensor electrical connector.
  8. Foreign object deflector.
  9. Sensor and pedestal from block face.
  10. Sensor from pedestal.
  1. Loosely install the crankshaft sensor on the pedestal.
  2. Position the sensor with pedestal attached on special Tool J 37089.
  3. Position the special tool on the crankshaft.
  4. Bolts to hold the pedestal to the block face, torque to 20-40 Nm (14-28 lb.ft).
  5. Torque the pedestal pinch bolt to 3-4 Nm (38-40
  6. Remove special tool J 37089.
  7. Place the special tool 37089 on the harmonic balancer and turn. If any vane of the harmonic balancer touches the tool, replace the balancer assembly.
  8. Balancer on the crankshaft.
    • Apply thread sealer (GM 1052080) or equivalent to the threads of the balancer bolt.
  1. Torque the crankshaft bolt to 140 Nm + 56°(104 lb.ft + 56°).
  2. Foreign object deflector.
  3. Electrical connector.
  4. Inner fender shield.
  5. Tire and wheel assembly, torque to 140 Nm (104 lb.ft).
  6. Lower the vehicle.
  7. Serpentine belt.
Jun 02, 2009 | 1994 Buick Regal Gran Sport
Washer vibrates and walks across the floor
Theres a few things you can do to stop it from walking.
but the best way i know is to use washer anchors.
Whirlpool part# 155P3 $22.95
Im going to assume that you have eaither the wfw8300 or wfw8400
the main differences is the suspention system in them. the 8300 uses a 5 point system that work but really you should only use the washer on solid flooring like concrete. the 8400 uses a 6 point with better shocks.
if you have this washer on a main floor with basment underneith it you might want to check the floor. grab a glass of water when it starts to shake and walk and put it on the floor, if the water is jumping then the floor is the problem.
eaither way the anchor kit i have listed above will stop your issues with it moving and walking.
Feb 07, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool Duet GHW9150P, Screws for Pedestals
You can go near hardware if nothing stock you may go to washing machine junk shop you can select any part as you wish.
Jan 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
452 people viewed this question
Dan Webster
Dan Webster
Sal De
