Question about Princeton Digital VL1918 Monitor
No volume We don't have any sound at all on our VL1917. Any suggestions?
  • 53 Answers
Being a person with some experience repairing Princeton Monitors... 776 so far.
If you have not had volume from the monitor right out of the box It would appear the speaker connector was not install or fell off due to poor installation at the factory.
Princeton Monitors have a lot of problems. when they work, they work well.
They are known for their very bad capacitors in the inverterboards.
If the unit runs but you have no green light and no picture Your Caps are toast.
As for your speakers, remove the front bezzel and look for the twisted wires usually black and red with a small white connector. If you find it just danggling, the connector it should go into is on the right lower side of the monitor's screen. It's keyed so installing it only one way will make it work.
Hope this helps.
Posted on Nov 07, 2008
Nokia 6303ci -low speaker level.Volume bar-on max.After clean -same.Someone told me that for this model is normal low speaker level,but I don`t think so.
If the original recording is on low volume then you will get louder sound on the player device while if the recording is at high volume the you get low levels on player. try recording at lower volume settings on the phone. Then when you play it it will sound louder on increased volume.
Oct 26, 2013 | Nokia 6303 Cell Phone
Cant find sound blaster control
Suggest you download AND install the application -
Creative WaveStudio,
(7.14.01)
http://support.creative.com/Products/ProductDetails.aspx?catID=1&CatName=Sound+Blaster&subCatID=231&subCatName=MIDI+Keyboards&prodID=20885&prodName=Sound+Blaster+Recon3D+PCIe&bTopTwenty=1&VARSET=prodfaq:PRODFAQ_20885,VARSET=CategoryID:1
It's the SoundBlaster soundcard 'Control Panel'.
Regards,
joecoolvette
(Don't forget about the Volume control in the system taskbar at the bottom of the Windows desktop screen )
Oct 10, 2012 | eMachines W3619 PC Desktop
I have no sound from my tv
Hi You don't need to use the volume on TV when you have it plugged into an amp/stereo.
also you should not have to turn the tv up to get sound out of. Turn your TV 1/2 way and then use your amp/stereo to crank the volume up.
Jan 02, 2012 | Element ELCHW402 40 in. LCD HDTV
The maximum sound volume of the built-in speaker is to low. One can adjust it to higher volumeand how?
Have you tried to increase the volume from the screen menu? I suggest you to keep the screen volume settings at maximum and adjust from the computer mixer settings.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jun 17, 2011 | iiyama AS4316UTC 17" LCD Monitor
I have loaded software for Canyon webcam CNR-WCAM43G I can see myself and am told it is loaded correctly, but when I call my brother, we can both see each other but there is no sound. Any suggestions...
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
don
Mar 01, 2011 | Computers & Internet
Hi just bought these speakers and only the right and left work?? any suggestions??
you might have to select stereo speakers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 15, 2011 | Logitech X-530 Computer Speakers
Acertravelmate4000 got it used,don,t know how to turn off mute,turn on or up volume
The volume may be muted. In Windows, look at the volume
control (speaker) icon on the taskbar. If it is crossed-out, click on
the icon and deselect the Mute option.
The speakers may be turned off. Press Fn-F8 to turn the speakers
on (this hot key also turns the speakers off).
The volume level may be too low. In Windows, look at the volume
control icon on the taskbar.
Fn-? Volume up Increases the sound volume. Fn-? Volume down Decreases the sound volume.
If this helps u let me know
regards
Jan 12, 2010 | Acer Computers & Internet
My Computer have an integral Realtek sound card,and Gigabyte motherboard. The option for mic volume is grayed out, and i just can`t turn it on. I saw in one forum that evryone have similar problem, but for...
You should update your sound driver. Update of Sound Card Driver.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Click on Sound, Video and game controller
  • Right click on sound driver from the list.
  • Click on Update Driver.
  • Update Driver Wizard start.
  • Realtek Sound Driver
Apr 25, 2009 | Computers & Internet
I don,t have sound cord in my pc
Click on Start, Settings, and launch Control Panel. Double-Click on the "Sounds and Audio Devices" icon. On the Volume tab, make sure the box, "Place volume icon in the taskbar" is checked. Uncheck "Mute" if it's checked.
Mar 22, 2009 | Microsoft Windows XP Professional
No Display on Monitor (Princeton VL1917)
Try leave it for some time and try it again to the PC, when you connected it to the laptop it must have auto configs it selfself too suit the laptops resolution.
Nov 24, 2008 | Princeton Digital VL1918 Monitor
Princeton Digital VL1918 Monitor Logo
147 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Josh Whitehead
Josh Whitehead
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
