Question about Western Digital MY BOOK HOME 1TB EXT HD-USB2/FW/E-SATA 3.5IN 1YR FireWire 400 Hard Drive
My WD 1T MYBOOK
Pc doesn't recognize. MAC recognizes the drive be cannot format - "resourse busy" I've tried using Norton on the PC and Disk Utilities on the MaC as well as StllerPhoneix. Right now, it's just a paperweight.
Any help?
    Sergeant:
  • 300 Answers
Oh boy , mac , well for starters if the drive was formated on a PC , the mac may not recognise it at all.
namely because mac partition and PC partition are two different critters.
the only method I know of to get a MAC drive partitioned and formated for a mac is use FreeBSD tools.
I can hear my fellow geeks laughing and mocking me in the background for my lack of knowledge on this one , but hey at least it gets you one step farther than you were before.
Posted on Sep 11, 2008
I am a new macbook pro owner. My new mac will not recognize my external wd mybook which is several years old. What do I do?
Hello!!
The MAC is not recognizing HDD because it may not be in FAT or MAC OS X Journeled Format.
Please Follow below steps to Reformat the HDD to make it Compatible with MAC.
1. Connect the HDD.
2. Open Disk Utility from Applications -> Utilities
3. On left side of Disk Utility you'll find your HDD.
4. Click on HDD and select the Format TAB.
5. Reformat the HDD in FAT Format.
6. Click Apply.
7. Done.
Hope it Helps..!!
Jul 07, 2011 | Apple MACBOOK PRO WITH PARALLELS NOTEBOOK...
MY WD can't recognize by my pc but last week i use it but there no problem but when i plug it again today in my pc the book are not be read and theres no icon that can be seen in the HARD DISK DRIVERS BUT...
Device Manager only says that the disk is getting AC power, and that the "data" cable is connected, and that Windows has recognized the specific device-information (that it is a disk-drive, and that the capacity of the disk-drive has been recognized).
Device Manager does not say that the "spinning" part of the disk-drive is still spinning, nor that there are any I/O errors (trying writing with a pen onto greased paper -- not everything you write can be read).
Try connecting the MyBook to a different USB port on your computer.
Try connecting the MyBook to a different computer.
If it still is not "readable", then you have a few options:
* if the warranty still is valid, exercise the warranty, to get it repaired/replaced,
* disassemble the case, disconnect the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a "slave" drive in some desktop computer, to see if the USB-to-disk-drive adapter has failed
* buy a replacement disk-drive, connect it to that USB-to-disk-drive adapter, and close the case, to create a "new" external disk-drive.
Oct 24, 2010 | Western Digital My Book Essential 1TB...
PC doesn't recognize Passport after Mac use
you must choose the format you wanna run on your hdd.mac and pc aren't the same.
Apr 16, 2010 | Western Digital WD Passport 250GB Portable...
I took a WD external drive and installed it as a second sata drive. Bios and Device Manager recognize it not windows xp explorer. I want the data so I can't formator use disk manager. Drivers are on the...
The Drve most likley does not have a partition or it has one that is from Linux or Mac. Use the disk manager snap in and see if it sees the drive. If so then create a partition on the disk then windows will assign a drive letter and you can format it
Jul 12, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
Mac not Reconize my MyBook
load the driver for mac use, the external hard drive comes with cd, the mac driver should be inside, load it to your mac computer. if you donot have the cd go online to western digital and download it. just load the driver and u will be fine, make sure u connect the cable in right places.
Mar 09, 2009 | Western Digital My Book Essential Edition...
MyBook not recognized by Mac
I am having the same problem!!!! I have my time machine backups on there and I cannot access them! Class action lawsuit???
Mar 09, 2009 | Western Digital 500GB My Book World...
How can i get get WD "my book" hd to also work with windows
Some solutions possible:
(Optional: - First split the video in chunks <2GB to make them more compatible with older filesystems and networking technologies)
A) Copy the file over the network (e.g. using Windows Sharing on the Mac, or using File and Printer Sharing on Vista)
B) Try to do it via the MyBook.  This means the Mac must be able to write something and Vista must be able to read it.  You say you've "set up" the MyBook "for my macbook pro".  How did you format it?  What filesystem?  Mac OS Extended (HFS+) with Journaling?  In general, you need to install something on Vista to read the Mac's filesystem format (HFS+), or on the Mac to write a Windows format (probably best to use NTFS).  Examples of software like that are:    (Win) MacDisk <http://www.macdisk.com>, MacDrive <http://www.mediafour.com/products/macdrive>    (Mac) MacFUSE with NTFS-3G <http://macntfs-3g.blogspot.com/>       or Paragon NTFS <http://www.paragon-software.com/home/ntfs-mac/>
B2) If you've formatted the MyBook as FAT32, you're lucky.  Just split the movie file in chunks <2GB, copy them to the MyBook, copy them from the MyBook in Vista and join the chunks again.
(for splitting you can use e.g. HJSplit and its compatibles <http://www.freebyte.com/hjsplit/>) (also check e.g. "NTFS on your Mac two ways" <http://www.tuaw.com/2007/11/19/ntfs-on-your-mac-two-ways/> for an alternative explanation.)
Jan 29, 2009 | Western Digital MY BOOK HOME 1TB EXT...
WD MyBook Studio works on Mac but not showing in My Computer (PC)
If the drive is NTFS formatted you can use/install MacFUSE.
Dec 29, 2008 | Computers & Internet
I recently purchased a Dell XPS 420 Desktop computer, running Vista, from Dell, including a WD 500GB MyBook external hard drive. The power button did not function from the get-go, but I was able to copy...
Unfortunately if there is no driver for Vista, then your out of luck. Since Vista is a widely used OS and getting bigger, then the MyBook manufactures must create a Vista driver soon or they will be in danger of going out of business. Just wait and periodically check the MyBook website for new drivers.
Feb 11, 2008 | Computers & Internet
Western Digital MY BOOK HOME 1TB EXT HD-USB2/FW/E-SATA 3.5IN 1YR FireWire 400 Hard Drive Logo
439 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
