Question about Sharp AR-507 Copier
Duplex printer Hi, I Have a copier/printer sharp ar337, this machine have a duplex system, but in printer mode this not printing two face, only printing one face. Can you help me for this print in two faces?
  • 24 Answers
Like mitch says update your driver and make sure your the configuration is correct i.e it displays a duplex system on your machine, they were sold without as well
Posted on Sep 26, 2008
    Problem Solver:
  • 13 Answers
Check the driver you have installed on your computer, that's where the duplexing would be generated from. You should be able to choose through print properties at this point. Here's the link to Sharp:
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Posted on Sep 11, 2008
Sharp ARM237 crooked prints and jams w/double sided printing only.?????????
this will be an issue with the duplex rollers check where it is jamming is it in the duplex unit if yes then check the duplex rollers for wear worn rollers will cause scews also check there is no torn pieces of paper stuck in the guides of the duplex
a good thing to do is to get a thin piece of card stock slide it into the duplex manually and frred it where the paper path goes on the duplex from beginning to end and it will push out any thing in the path
Jan 20, 2011 | Sharp AR-M237 Digital Copier
I want duplex printing for hp 2420
The only way to duplex print on a standard 2420 is to print the first page, then take that page and re-insert it into the paper tray face up. Then print page 2 onto the back of page 1. If you want to automatically duplex print then you need a 2420DN printer which has the duplexing paper path as well as the formatter board with the duplex firmware.
Good Luck and Thank You for using Fixya.
Sep 23, 2010 | HP LaserJet 2420 Printer
My HP 4700 printer suddenly can not print on both sides, yet it used to print on both sides. I can't see the option for duplex on its printing menu. Pls help
You can enable duplex printing from your computer, if it somehow got turned off. Open the printer program, and under Configuration Settings, click Duplex Mode, then click Enable Duplex Mode and then Apply.
At the printer, you can find the Duplex options by clicking Menu and scrolling down till you see Configure Device. Duplex is in that menu.
Aug 06, 2010 | HP LaserJet color laser printer
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
How to print back to back pages on sharp Mx-2300N
Back to back mean duplex print .If your copier has a duplex cassette you can use duplex print before configure it see your user guide and follow this function.
Dec 14, 2009 | Sharp MX-2300N Color Copier
Can't get Oki to duplex
some of the oki's & hp's wont duplex on the network without a print server, know it's a shot in the dark but is it connected to a print server or directly to the network.does it give any errors or just fail duplex and comes out single sided?
Jul 28, 2009 | Office Equipment & Supplies
Duplex mode.
please select print in both side options when u giving any print then only it will print both side...
Jul 02, 2009 | Kyocera Mita FS-1030D Laser Printer
Canon imageCLASS MF6530; can't set up duplex (2sided) printing
hi there
there are 2 ways to copy 2 sided
one is full duplex which means your copier must have a duplex attatchment fitted on the copier lid
the other if it hasn't got a duplexer is to copy in 1 to 2 mode which means you have to turn the copy over. it sounds like your machine has not got a duplexer fitted but it can still do double sided using 1 to 2.
hope this helps
beergut707
Oct 15, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Duplex printing
The HP Laserjet 4+ does not have duplex capability built in; you'd need to purchase and attach the duplex unit (HP part number C3157A) to have that option.
Depending on your operating system, your driver may support a "manual duplex" mode in which you print one side, reload the paper, and then print the other side. You can also "fake" this from many applications (such as MS Office / OpenOffice) by telling it to print only even-numbered pages, then printing only odd-numbered pages.
Nov 13, 2007 | HP LaserJet 4 plus Printer
Sharp AR-507 Copier Logo
82 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
