Question about RCA P52830BL 52" Rear Projection Television
Snow on screen/wiggle the coax
I have a p52830bl. Once I turn the tv on it works fine then after about 5 min the picture turns to snow with some of the programing still viewable. I have "wiggleled" the coax cable and the screen will clear up then go back to snow 15 min later. (pain when trying to watch a 2 hr movie) I have tighted all the connections in the back and it still doesnt help. I just have to keep movinng the cable in the rear of the tv to get the picture to clear. I also hooked the coax to a diffrent tv, thinking it was a bad cable however the cable works fine. Can I replace the board and where do I buy one? Also where can I buy a reasonably priced screen? thanks, lost in winter wonderland.
  • 38 Answers
SOUNDS LIKE BAD SOLDER CONNECTIONS IN SIDE THE TUNER. TAKE THE BACK OFF AND TRY TAPPING AROUND WITH YOUR DRIVER HANDLE THIS WILL LEAD YOU TO WERE THE PROBLEM IS. THEN WE TAKE THE TUNERS APART AND RE SOLDER THE CONNECTIONS,BUT YOU HAVE TO BE VERY GOOD OR YOU WILL MAKE MATTERS WORSE.
Posted on Apr 11, 2006
Screen freezes, and buttons don't work!
It sounds that the main digital board to your TV has the fault. To check and locate the fault to this board is a very skilled work. Contact any service technician.
May 28, 2013 | Vizio SV421XVT 42 in. LCD TV
I cant change my VT2230-M to the tv setting. I turn it on, the power light turns blue, and then the parrots come up. then the Monitor goes blank.
I had the same problem. It appears to be due to a bad tv tuner. Turn on your computer and leave the coax unplugged. Leave it for a while (15-30 min). When you see "snow" on your screen, you will be able to use the source button to change to another input and see if you can get a signal. I am running my cable through a dvd recorder and using the AV input to watch tv. Also, my HDMI, component and RGB work fine. After thank don't try to access the TV source until you have had your tuner replaced.
Apr 12, 2011 | ViewSonic VT2230 TV
RCA 27 inch ColorTrak Plus. TV is hooked to cable. I can produce the problem by wiggling the coax connector. The screen goes through various degrees of snowy-ness until I find the sweetspot on the coax....
The failure with this TV is due to faulty ground in the tuner that is why when you wiggle the cable connected to the tuner the picture clears up. If this failure is not repair, it will corrupt the data on the eprom until the TV will not power ON anymore.
Check the info from this link to find more info on the failure of your TV.
Let me know if you require further assistance.
Apr 12, 2010 | RCA F31672ET TV
How do I repair where the coax cable connects to my 13 in TV
go to RADIO SHACK and get a RF MODULATOR ,this will do the trick , good luck , AJ
May 22, 2009 | GE 32GT740 32" TV
Direct tv has snow in picture cant see nothing
First, how is the receiver connected to your TV? If it's via coax, the most likely culprit is the coax from the TV to the rcvr. If you wiggle the coax and the snow goes away, you've found the answer. If it goes away, either get a new piece of coax or tighten the connection at both ends.
Jan 17, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Snow on screen and no picture on my DS35510
Hi and welcome to FixYa,
Offhand, if the previous system/connection works then we should leave that as it is. Coax-Sat Receiver-Coax-DVD Recorder-TV and TV should be Channel 3 (or 4).
On the new Sat Receiver, coax from LNB/Dish to Sat Receiver, yellow, red & white to TV. TV should be set to Video 1 or A/V or Video. There should be no snow, rather if no reception, it should be blue indicating video has muted in the absence of a good signal.
Good luck and Thank you for using FixYa.
Jan 04, 2009 | Sanyo DS35510 35" TV
Sony tv snow for first 5 minutes on
Probably dry solder joints in the tuner section.
When the set warms up, the faulty joint/s make contact, then lose contact again when it cools down.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Female coax connector in tv bad?
Did the cable person take a reading on the signal level at the cable outlet on the wall and did the cable person check the TV setting to make sure they are correct. TV could be set on the wrong channel also.
Nov 08, 2007 | Televison & Video
RCA P52830BL picture is bowed and colors separated.
There is a convergence printed circuit board that likely has a few bad components. If you decide to get it repaired, the technican will probably check for fluid leaks from the picture tubes coolant area which has given problems on this model also. If the picture quality leaves a bit to be desired, it may be a wise move to upgrade to HDTV. A Sony KDS-55A20 model has a great picture and should be less than $2300. I just saw one at a local Sams Club store.
Mar 12, 2007 | RCA P52830BL 52" Rear Projection...
Televison & Video Logo
94 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
