Digital tv tuner Converter box
Hooked up the converter box and everything works fine except I cannot get a major tv station ABC. We adjusted the antena, but that didn't help. I just get "NOSIGNAL"
  • 374 Answers
Your ability to receive stations will be based on the the type of antenna you have. There are three typical types: a Yagi ( It is the traditional type) it is uni directional ; bi--directional; and lastly omnidirectional. Both the Yagi and Bidirectional need to be pointed toward the local ABC affiliate tower to receive signal this may result in loss of others channels at that time. Finally all antennas have a range that they are effective. Check the range of the antenna you have. If you go to they can tell you the proper azimuth for pointing your antenna and they will give you a breakdown of the towers so you can see the specific tower you need to point toward to get ABC and if I remember correctly they give you the distance from your location to the tower.
If you have any questions post a comment to this solution. Hope this helps you.
Posted on Sep 10, 2008
Attach tv converter box
Everything is digital now. You will need a digital converter box. You will connect an antenna to it, and then connect the box to your tv. The box will come with it's own remote. Your tv will be set to channel 3 or 4 (depending on the converter box you get), and you will control the stations with the remote that came with the converter. You can get them at any electronics store.
Jan 09, 2014 | Jensen J53-BWR 5 in. Portable Television
I have a 13' Orion tv, model #TV1326BW with rabbit ear antenna. I have connected everything correctly to the converter box for digital signals. I can pick up all stations except the local CBS affliciate....
I have the same TV & cannot get into the TV menu to program the cable... it was bought secondhand without the original remote. There are no buttons anywhere on the TV itself to bring up the menu & the universal remote's menu option doesn't do it, either... how do I set the channels?
Aug 04, 2009 | Televison & Video
Can't get digital converter box to work with Toshiba TV/VCR Combo
You will need to rescan your stations. On the June cutoff date, they reshuffled and renumbered most of the stations.
Jun 16, 2009 | Insignia Digital-to-Analog Converter for...
How do I use my VCR with the DTV Converter Box that I had to get?
You only have three choices that I know of. The first two are a bit expensive though. 1) Buy a digital TV, then you could split your antenna cable to the TV and Converter box. Then use the converter box as the tuner for the VCR. 2) Buy a digital VCRand do the same thing using the converter box as the TV's tuner. or 3) Get a second Converter box and split the incoming cable between the two, using one for the TV and the other for the VCR. If you use any of these ideas, remember that You need to not have the VCR and the "new" tuner for the TV set to play on the same TV channel, and that you switch teh VCR out of VCR mode with the TV/VCR button, so that you get a clear signal on the other channel. If anyone has an easier solution, I too would like to know about it, seeing as I am in the same position and would like to avoid this problem as well.
Jan 02, 2009 | JVC HR-J692U S-VHS VCR
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Lost ba channel
if You have cable maybe you have a bad line
but if you just have an over the antenna lots of station are switching to digital early so maybe your station is not brodcasting analog then you would have to buy a Digital Converter Box
Sep 07, 2008 | TruTech PM1919BXA1 19 in. LCD TV
Convertor box and Sony Wega with PIP (2 Tuners) and new Digital DVR/VCR
I wonder if the RF interference from the digital tuner. That box will only allow ouput either through the coax or the AV ports. If you do both you will not get a picture.
If you switch them you have to tell the box what your using for output by going through the setup process.
Is the Zenith 901 converter box for your cable TV.
Aug 17, 2008 | Insignia Digital-to-Analog Converter for...
Insignia NS-LCD32 TV
The tuner section, and or the voltage regulator circuit that supplies it is probably failing. The service rep for your set may be able to order a new tuner module and install it. This is not a type of repair you can do yourself.
Jerry G.
Jun 18, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia NS-DXA1 - Digital to Analog converter box
I have had my converter box 5 days now. I hooked it up to the TV and set it up. No Problem. Except there are no instructions on how to set up the VCR/DVD player with it, which we use more than we do watching TV. Everything worked fine until on the second day we had it I read I could program the remote to turn the TV on and off. I followed the instructions and the TV went off. When I turned it back on, my remote went berserk. If I try to change a channel it will quickly flip through all the channels until I turn the converter box off. Same with the volume, it goes up and down, up and down until I shut off the box. The remote does not work unless you are about 1 foot away from the box. And the remote has never turned the TV on or off except that first time I programed it.
May 19, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
