The t-con board is always at the top/middle if all lcd's. If it doesn't have one visible then it is built in the display and therefore non serviceable. If it is visible and after replacing it does not cure your problem then the display panel is bad then the set is scrap. The display will cost as much if not more than a new set.
Testimonial: "Thanks very much it was helpful, as much as the time you took to answer this question."
The T-Con board is connected to the panel of the tv. Try out these guys for parts, I have used them with great success in the past. Hope that helps!
[email protected]
http://www.shopjimmy.com/catalogsearch/result/?q=DP26648
