Question about Refrigerators
Whirlpool GD5shaxlq02 low voltage to ice maker
The voltage to my ice maker is 39 VAC. The ice maker module is good. What is causing the low input voltage???
SOURCE: whirlpool ice cube maker not functioning
Comment regarding catriver Aug 18 post: Shorting L&V caused valve to work I believe, at least I think I heard it operate, but shorting T&H did not cause gear to move. So does that indicste a different problem? Still no ice. JimB
Posted on Oct 05, 2007
peyton32034
  • 410 Answers
SOURCE: Ice maker not working
the icemaker will run at 120v ac +- 10% so 108 v is within range altho marginally. since you have the icemaker removed. remove the front cover and check to see if the drive gear is broken or if the 2 center pins that hold the gear in place are twisted or broken. this is most likely the problem. the motor module can be replace very easily part # is 8201515
the normal home position for this icemaker is at the 2:00 position facing the front of the icemaker. if it is any other position the motor module is almost always the culprit..
Posted on Dec 18, 2007
SOURCE: Whirlpool Side by Side Refrigerator Model # ED2FHEXNQOO
on a whirlpool side by side i get water from the door but no ice. i put power to both sides of the selinoid and it worked fine. it acts like what ever askes for the water to the ice maker is not working. it will despense ice fine if you put ice in the bin.
Posted on Apr 08, 2008
  • 10 Answers
SOURCE: Whirlpool GD5SHAXLQ02 ice maker quit working
The the rubber fill spout was frozen with ice. Also the reservoir that acts as a funnel for the fill spout was frozen with ice. Cleared the ice and all works fine!
Posted on Oct 03, 2008
heatman101
  • 43501 Answers
SOURCE: ICE MAKER NOT WORKING WHIRLPOOL ULTRA EASE II
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
' 8798yuiy
Posted on Sep 30, 2010
Is there a way to test the control module for my ice maker? The model number on the control module is W10190935. The ice maker is not getting any water. I have tested the water inlet valve and it is...
The ways to test the icemaker is of course have it installed into the i/m mold and connected to the plug in freezer to test it;
meter leads in the L&N holes on module should have 120 volts ac at all times,if not the thermal fuse on the wire from i/m module is blown, to test that the plug where the i/m plugs into should have 120 vac all times on the black and white wires in that plug from freezer wall into i/m
If 120 vac on L&N use jumper wire and jump the holes marked T&H,the i/m should start, may need to wiggle jumper till it starts,then you will hear click within 10 seconds remove jumper as soon as clicks, the im will rotate , if you think of fingers on i/m a hand on clock when the fingers are somewhere between the 10-12 o'clock area their should be 120 vac at water valve if 120 vac try again and plug water valve back in if no water fill when fingers are 10-12 o'clock water valve is bad
A WORD OF WARNING THOUGH IF YOU TOUCH A BARE WIRE ON JUMPER IT WILL SHOCK YOU,so only strip about 1/2" of each end of the jumper wire and bend into a U shape before inserting to jump i/m and wear nonconductive gloves
Good luck,
Gene
Aug 11, 2011 | Maytag Icemaker Motor Module Assembly...
Why is my ice maker filling up my ice tray with water then freezing it like a block of ice?
There are some adjustments that you can do if you carefully follow the instructions in the video below. I also have a Whirlpool Ice Maker Troubleshooting and Service Manual upon request. Your 67003753 Water Inlet Valve=> 67003753 Water Inlet Valve could be leaking and creating this block of ice. For most Whirlpool/Maytag brand ice makers is is cheaper to replace the core module part number=> D7824706Q Ice Maker Module. Reason being the individual parts add up to more than the cost of all those parts together. Now if interested you can request a Whirlpool Ice Troubleshooting Service Manual by filling out the capsha=> HERE Reason I don't place the manual's here because Whirlpool ask me not to do so, but I will be glad to send you one. The manual is the solution but the most complete module or replacing water valve is the cheapest route. Below is how it is explained a little simpler. If I can help you in any way please ask, Thanks, Sea Breeze
If helpful please rate this solution.
Jun 21, 2011 | Maytag MBF2256H Bottom Freezer...
How to repair an ice maker in whirlpool side by side refrigerator?
For most Whirlpool brand ice makers is is cheaper to replace the core module part number=> 2198597 Ice Maker Assembly Reason being the individual parts add up to more than the cost of all those parts together. Now if interested you can request a Whirlpool Ice Troubleshooting Service Manual by filling out the capsha=> HERE Reason I don't place the manual's here because Whirlpool ask me not to, but I will be glad to send you one. The manual is the solution but the most complete module is the cheapest route. Below is how it is explained a little simpler, Thanks, Sea Breeze
Jun 20, 2011 | Whirlpool ED5FTGX Side by Side...
KENMORE 106.53644300 ice maker type 2 with front door dispenser. ice maker stopped making ice, than 3 days later started again then stoped, day or so later ran again then stopped. I removed the unit put...
That is a Whirlpool module type ice maker that seems to have has been so strict with their information I will need to give the manual's another way about a 5 year life span. I have some manuals but because Whirlpool stopped letting people post what they believe is their property. I guess I need to only understand but if I place them here I will lose my subscription. Click Here=> My E-Mail and I will send it to you. May have to fill out the capsha first. Below is what I am talking about as far as how they work and yes I have the schematics and tech sheets, I will look to hear from you, Thanks, Sea Breeze
Click Here=> 8201515 Ice Maker Module
May 05, 2011 | Kenmore Refrigerators
Ice maker will not dump
Good day,
It has to be the ice maker itself, as long as the temp in the freezer is at or below 14 degrees, and the lever is in the down position.
2 items internally can cause the problem. One is the front module which is a quasi-solid state component and the control thermostat which is behind it and requires a complete dissasembly of the ice maker to access it.
Most will simply replace the ice maker.
If you feel you want to try a repair, remove the ice maker, and let it sit on the counter for 24 hours to dry out.
Pull the front of the wire lever out of the body of the ice maker. Pry the front cover off the ice maker. You will see 3 screws holding the module in place. Remove them, and pry the module off.
Re-install. The point is the electrical contacts are press to fit and one or more might have failed to make a good electrical contact. Reassemble and reinstall the ice maker.
Rarely works but your option. Replacing the module and thermostat are not cost effective.
May 06, 2010 | Whirlpool GS6NBEXR Side by Side...
My ice cubes appear to be hollow. what is causing this?
The water valve is not letting enough water in . Replace the water valve .
Aug 06, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Oct 01, 2008 | Refrigerators
Ice maker issues
The boards put the 120 volts to the ice maker. If you open the door the red light on the board in the center should blink two time repeatedly. If you push the flap on the left in the light should be solid. If you push in the light switch for the door the light should go out.
Apr 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
163 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
