Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Cap replacement didn't entirely work dead tv problem half fixed
I read on here about the blinking light that wont go away after a service man came charged me 100 dollars and said the dm board was bad throw the tv away.i found the caps and replaced them i got the tv to power up now but no picture just a few squiggly lines of color and no responce from the front buttons or the remote and after ahwile the tv shuts itself off thank you for any help i think at least it's starting to get better just don't know what to check from here
  • 5 more comments
  • csccfarrell Sep 11, 2008
    thank you for answering yes i replaced all 4 and they are direct replacements all numbers match on the caps 1000uf 16v 105c only difference is different brand and taller i double checked the polarity while i was doing it and again now it's marked on the board pos and neg and the caps have the same neg stripe down the side as the old ones.i can't find any wires off anywhere and the first time i set the board it didn't power up and i had to reseat it by leaving the case loose and seating the board by itself then sliding the case the rest of the way down that made it power up but i get no picture just a fer color lines and none of the controls work accept on and off and it shuts down after a couple minutes on it's own. i am very new at this never worked on a tv before so any advice i get is very helpful i had a repair man out he said it had a bad digital board had to be replaced not available is it possible he moved wire plugs while working on it some of the plugs look the same in there but they are all plugged in as i found it thanks again for the help.
    don't know how to get a picture on this but i'll do my best to describe it the screen after it turned on had thin wavy lines going horizontaly acrss the screen all three colors like threads in a wave pattern hard to see not bright weaving into each other if i did take a picture you would never see them too dark a screen the bulbs inside the set were flickering when it was on i'm not sure what you want to see on the dm board i'll try to get a pic on here if you can tell me what you want to see thank you very much for the help.
    chris.
    the repairman did open the front of the set i don't know what he did i know he never opend the dm board he just said it was bad there are plugs inside empty next to ones with plugs in them i didn't unplug anything but is it possible the repair guy tried different spots for the plugs? and i really really appreciate this tim i can't afford a new set or another hundred buck for some guy to tell me it's shot throw it out i never worked on a tv before in my life but when i read about all the people on here with the same problem it was worth a shot and i do have power now just no picture thanks so much.
    chris.
    turned them counterclockwise no picture at all now just black screen light is on but no lines or anything i turned it off
    ok i turned it up till i could see lines one color at a time like a weave all across the tv then turned it down till they went off then tried for a 1/4 turn but they were only turned clockwise barely a 1/4 turn before the lines showed up now black screen nothing from the menu button or channel or anything no picture
    i just walked away from it and left it on and it shut itself off in a couple minutes.
    yes it is plugged in it splits to two plugs on the board under the red tube one labeled sm and sp
Trying to hang tv but don't know how too take apart the stand on the bottom of tv
Posted on Oct 07, 2008
    Novelist:
    Champion:
  • 203 Answers
Did you replace all 4 caps in the board? And did you put them in with the correct polarity? Also check to make sure that no wires came loose durring the repair and that you got the dm seated back in the tv right. Also what size caps did you put in?
Tim
Posted on Sep 11, 2008
  • 5 more comments
  • experttv
    experttv Sep 11, 2008
    Can you post a picture of what you are seeing on the screen and a picture of the top and bottom of the board where you were soldering? If you cannot get pictures then please describe the lines you are seeing in as much detail as possible, are they vertical or horizontal? what color are they? where are they on the screen. Let me know so i can help you?
    Tim
  • experttv
    Ok you have retrace in all three tubes, at this point we need to be carefull, we dont want to damage your set. Either there is a cable unpluged or someone turned up all the screen controls. Did either you or the repairman open the front of the set? If noone opend the front of the set then you must have the 200v line unpluged. Let me know about opening the front of the set, and in the meantime I will pull a manual and find the 200V line plug.
  • experttv
    Ok well hopefully he turned up the screen controls. Take off the front of the set and look at the black box with 6 control knobs on it. this is called the focus block, look closely at it with a flashlight to see what 3 are for focus and what 3 are for screen. (the top 3 should be screen and the bottom 3 should be focus if im not mistaken). turn all 3 screen controls counter-clockwise as far as they will go then turn the set on and let me know what happens
  • experttv
    ok, now we are getting somewhere...I want you to turn it on and slowly turn up each screen one at a time untill you get those lines, then back it off untill you dont see the lines again then go 1/4 turn furthur. Do this for all 3 screen controls and let me know if you have a picture or not (if you dont have a signal hooked up to the tv you can just press the menue button and let me know if that shows up.
  • experttv
    Ok looking from the back there are 3 big boards in the bottom of the tv. We want to look for the one on the right and look for a cabel labeled PM it should have 7 or 8 wires in it. and should run up to the little board hanging off of the red tube. That set should shut off with no signal after a few mins dont be to worried about that as long as it comes right back on. We need to make sure that PM is pluged in on both ends
  • experttv
    experttv Sep 12, 2008
    Sm and SP are pluged in as well? At this point do you know how to use a meter? Give me a call if you like 904-885-2203
    Tim Nolan
  • experttv
    Try taking the dm out and putting it back in let make sure that its connecting on all pins. also if you can send me some picture of the work you did on the board that would be good.
Replaced 3 capcitors today and tv still wont power up, element flx3711b lcd tv
check D7 and small cap to the right(forgot # returned tv) in the power supply area.i found diode leaky and cap dry.Thats how i fixed the blinking red light.hope it works.
Mar 07, 2011 | Element Electronics FLX3711B 37 in. LCD TV
The red standby/power light blinks and the tv screen is blank. Could this be the bulb?
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Dec 14, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
I have a 52 inch Magnavox Plasma TV that was purchased 4 and a half years ago. It is mounted on our wall in our family room. Recently we had issues with the tv warming up and not turning on right away. The...
The problems with ur tv is the power supply board,it dead.That the board,where the power a/c plug in to it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Dec 11, 2010 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Red light blinking tv wont turn on
Probably it had a short circuit. Hope you have warranty, because your going to need it.
Nov 07, 2009 | Philips 42PF9630A 42 in. Plasma Television
Panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Oct 13, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Lost green color, lights blinks
Ur high voltage is dead,FBT,flyback transformer is dead,the big black block of plastice with a red wire with a cap hook to a CRT(tv tube).Resoder for lost green color,by the crt yoke RED GREEN YELLOW connection to the main PCB board.Might also have to resolder crt board connection pins socket.
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
Jan 01, 2008 | Zenith Z37LZ5D 37 in. LCD TV
Sony wega 50 " lcd rear projection
The 3 blinks on this model TV means you have a lamp cover error. When you install the cover look at the tab on the cover and make sure it is making contact with the micro switch inside the lamp housing.
Oct 17, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
T.V. won't turn on
PCB repair should be done by a qualified tech. Your problem could be HV cap bad,xformer defective or bad connection problems and pico fuse open. Check 2KV cap near xformer.
Sep 26, 2007 | Sony KP-51WS520 51" Rear Projection...
Mitsubishi WS-65809 turns off right away
check 2 5amp chem fuses. in middle of tv. yellow or orange in color . if bad replace the 2 stk convergence ics and fuses.
Nov 06, 2006 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
