Question about Sony Handycam DCR-PC330E Mini DV Digital Camcorder
Sony handycam DCR-PC330E Mini, purchased in Tokyo, April 2004 - Was working as normal, then suddenly went 'dead' - no light showing when on charger (which had been working fine up to date), tried another battery, but still no sign of 'life'. Usually, when battery low or flat, functions like the operate button and cassette eject, still work. Currently, the camera is completely lifeless.
  • uljanovas Aug 15, 2008
    cassette playback pixelation
  • Anonymous Jan 21, 2009
    SELECTOR SWITCH DO NOT CHANGE OVER FROM CAMERA-TAPE TOMRMORY OR PLAY/EDIT.
    IN CAMERA-TAPE MODE WORK AND RECORD PICTURES.
    President:
  • 3,130 Answers
This is not a monster you wanna open and play with as I've seen this puppy and its loaded with flex cables connecting all the differant pcb's together. You wanna take this or send out to a camcorder specialist please. You also need a special set of these cables to work on this unit as well as a few special service jigs. Good Luck
Posted on Apr 12, 2006
Cant instal drivers
usb streaming function is not readily supported by windows vista. this would depend on the software that came supplied with the camcorder. unfortunately, the software being incompatible and the funtion (usb streaming) not supported by driver included in the supplied cd-rom, usb connection will not work (although you can use it for still picture transfer). for tape transfer you would need to go another route which is ieee1394 (ilink or firewire) connection. it should be a plug-and-play connection. your computer should support and have a working ieee1394 (ilink or firewire) card installed. a compatible ilink cable for both devices and a video capturing software like windows moviemaker and having all the needed hardware and software then your good to go. hope this helps.thanks:)
May 29, 2010 | Sony Handycam DCR-PC330E Mini DV Digital...
I HAVE A sONY dcr-tRV33 HANDYCAM RECORDER circa 2004. Just purchased new HP computer and it doesn't recngize the camcorder. What do I do? Rich
The application and drivers are not installed properly, reinstall the software from the CD along with the handycam. Its just a software problem.Or click here to download the required software.
Thanks.
Nov 24, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
DCR-PC330E to MacBook Pro
unfortunatley all sony products only work on pc your best bet would be to transfere to dvd and import that way
May 27, 2009 | Sony Handycam DCR-PC330E Mini DV Digital...
Sony DCR HC 40 E driver
I had purchased the laptop with Window Vista Home Premium OS. I am unable to connect my Mini DV Sony DCR HC 40 E through firewire. the laptop doesn't recognise mini DV. Please suggest proper driver & solution
Aug 16, 2008 | Sony Handycam DCR-HC40E Mini DV Digital...
I have a Sony Handycam DCR-TRV22E Mini DV Digital camera and cannot get my PC to recognise it.
Go to camera menu and enable USB Stream, problem will be solved and PC will recognise your camera.
Jun 21, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
Supported USB drivers on Windows Vista
There is no driver available for this model. Sony sucks !!!
May 24, 2008 | Sony Handycam DCR-TRV22 Mini DV Digital...
Sony DCR-PC101E recording kaput
hit it really hard, worked for me with c:31:23.... google it too
Jan 28, 2008 | Sony Handycam DCR-PC101E Mini DV Digital...
Draining battery
This camera has had problems with the primary switch block faulting. The camera will power up all by itself when unattended and drain the battery. Another symptom would be the battery refuses to charge fully because the camera must remain in the "OFF" mode for the charge process to begin. Sony in Laredo, TX is replacing these controls at little or no cost, I would call them to see if they will repair this for you. Hope this helps you. Joe Weibel Custom Electronics (customelectronics.org)
Feb 11, 2007 | Sony Handycam DCR-HC40E Mini DV Digital...
Sony Handycam DCR-HC30 2004 model
Your unit is a 2004 model. If it has never been used since then the battery is probably no good and will need replaced. Batteries discharge 20% on a monthly basis just sitting on the shelf so yours went dead a long time ago. Then if they are left in that state (dead) they sulfate which means that sulfur oxides transfer to the plates and form an insulating surface. At that point all the charging in the world is not going to bring it back. All you can do is get another one. They are available at most stores which sell electronics. Get a new battery and charge it per the instructions and try using it again. This should solve your problem. Good luck.
Jun 13, 2006 | Sony Handycam DCR-HC30E Mini DV Digital...
Sony Handycam DCR-PC330E Mini DV Digital Camcorder Logo
219 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
